I don't know about the other x-pipes, but I have the Bassani and it has been a good purchase. The fit and finish is very good and it solved much of my popping and resonance. I bought mine at one of the major Corvette events and got a great price.
I had a Magnaflow ordered and installed at a muffler shop(magnaflow dealer) for a great price. Much less than me ordering and doing it myself and its welded in. I liked their design best.
My local wheel/muffler shop had about a 15" X-pipe section made by Magnaflow that fit in place of the stock H-pipe section. They cut out the H-pipe section and welded in the Magnaflow X-pipe. Worked great and saved some $$. The factory 2.5" exhaust pipe is really not bad. Muffler shop guys said it was thick stuff to cut.
My H-pipe has a crack in it.... That's why I'm changing it out...
The crack was found while installing the Borla's...
Thanks for all the opinions.
K.K.
From: I'm not quite middle aged and I only own one gold chain! San Jose CA
When you carefully study the fit and finish and how the X chamber is configured, the Bassani is the hands down winner in my book. They can be a little more expensive than others, but just compare the pictures and you can see why. You get what you pay for. In order to do it's job well an X pipe has to be more than just two exhaust pipes welded together. Many of the pieces for sale appear to be no more than just that, while the Bassani has a carefully engineered central chamber. It makes a big difference in performance and sound.
I ordered the Bassani for the reasons you stated... Just looked like had the best x chamber.
The guys at Corvette Garage had the best price; $45 less than Mid-America......... I've dealt with M.A. for the past 15 years, but they were alot more proud of their pipe....... They are local, that's why I like them, but I'll shop around from now on...
Anyway, Thank you all for the opinions. This is a great forum...
K.K.
I could only recommend an X-pipe as a means to turn the volume of sound down on your ehhaust system. Don't put one on because you are trying to add 3 to 5 HP cuz you ain't gonna get it.
Some exhaust systems sound better with an X-pipe and one is Corsa Indy's. If Borla is a bit to loud add an X-pipe.
If you are dead set on adding HP, open up the hole in the H-pipe. It is a lot cheeper. GM closed up the hole for a reason. I would sure like to know what it is.
I have a MagnaFlow X pipe with Corsa Indy's. Bought MagnaFlow because the design looked to be superior to the Corsa. I also liked the Bassani for its design but didn't buy it.
