[Z06] Center Console Heat
Old Dec 1, 2004 | 02:58 PM
Marine's Avatar
Marine
Default Center Console Heat
I took a drive down to SD airport yesterday to pick up a friend and noticed that the inside of my center console was HOT. The lid kept the heat from transferring to the inside but I mean it was HOT in there. Hot enough I was worried about my cell phone being in there.
Now isn't that heat Tranny heat? I hadn't noticed this before 'cause I never go digging in there while driving. But the tranny shouldn't be running that hot. Fluids are fine. Driving was "normal". Not that long of a trip (40 miles or so).
Any ideas? Or is the console just not that insulated?
Even just the carpet of the center console in my ‘66 Chevelle insulates enough to keep the heat out.
Thanks.
Old Dec 1, 2004 | 03:19 PM
dragon84's Avatar
dragon84
mine gets hot too, not sure if that is good news for you or bad news for me???
Old Dec 1, 2004 | 03:23 PM
Morzoff's Avatar
Morzoff
I think they all get "HOT" (Mine to)
Old Dec 1, 2004 | 03:55 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Not sure why but mine does it too
Dave
Old Dec 1, 2004 | 04:12 PM
USA1 427's Avatar
USA1 427
Ditto.
Old Dec 1, 2004 | 05:26 PM
Marine's Avatar
Marine
Thanks gents. If the cell phone fries in there, I'll consider it justice enforced by my Z06.
Old Dec 1, 2004 | 05:38 PM
AU N EGL's Avatar
AU N EGL
Heat comes from the Headers and exhaust pipes.
when I put on long tube ceramic coated headers that was the first thing I noticed, no heat in the foot well or between the seats.
answer to heat in the foot wells and between the seats are LONG TUBE CERAMIC COATED HEADERS.
Plus headers give you a few extra ponies to play with
Old Dec 1, 2004 | 06:18 PM
dragon84's Avatar
dragon84
HMMMM.. so long tubes are a safety mod????
Old Dec 1, 2004 | 06:21 PM
MikeP's Avatar
MikeP
All C5's are like that due to the exhaust system being routed through the tunnel/ center consol area of the car. I would also go with the ceramic header option to cut down heat and increase performance
Mike
Old Dec 1, 2004 | 06:40 PM
mountainbiker2's Avatar
mountainbiker2
I just added one of those 1/4" thick tunnel plates. No more heat in center console. The car will ride a little rougher. No performance gain in cornering either. Does take the heat away though.
Old Dec 1, 2004 | 06:47 PM
IGO200's Avatar
IGO200
I'm sure you know this- that I really needn't point it out, 'cause I'm sure you've studied up on your new car, so please forgive me if I'm pointing out what you already know, but the "tranny" isn't under there. It's back next to the diff.
Old Dec 1, 2004 | 09:52 PM
Steverino's Avatar
Steverino
What IGO said. ;>)
When I installed my SIRIUS radio system and had the interior torn apart, I put some heatshield down under where the console is and it took care of the heat problem.
Old Dec 1, 2004 | 11:29 PM
l2vette's Avatar
l2vette
How do you spell R A C E C AR !
No Heat, no race car.
Old Dec 2, 2004 | 01:36 AM
Marine's Avatar
Marine
Thanks. I spell it the same way.
Old Dec 2, 2004 | 01:49 AM
xsiveone's Avatar
xsiveone
Add a tunnel plate or tunnel shield and it will keep the heat out of the center console.
X
Old Dec 2, 2004 | 09:54 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Jet Coated Headers, Tunnel Heat Shield, & Dynomat Extreme = cool center console.
Old Dec 2, 2004 | 10:20 AM
AU N EGL's Avatar
AU N EGL
Of course also makes them easer to explain to the wife.
Yes a tunnel plate would do the same thing, but will the tunnel plate provied a few more HPs and a new sound at WOT???
or as ZO6-JIM said, get them all
Old Dec 2, 2004 | 11:20 AM
XmentalPilot's Avatar
XmentalPilot
From: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
I like to spell it backwards...
To Center Console Heat
