[Z06] What trans fluid
Old Dec 1, 2004 | 10:04 PM
Cruncher's Avatar
Cruncher
Default What trans fluid
I'm going to have the trans fluid changed. The stock Dexron III turned brown and caused shifting problems. So, what would your brand be?
Old Dec 2, 2004 | 12:15 AM
Jim M's Avatar
Jim M
St. Jude Donor '08
I put Mobil1 synthetic ATF in my Z, works great. I also used it in my 99 6speed with no problems. Amsoil and Redline are other popular choices.
Old Dec 2, 2004 | 12:36 PM
RoHo's Avatar
RoHo
I use Royal Purple, you can really tell the difference as it shifts some much smoother.
Old Dec 2, 2004 | 01:16 PM
DaveJP's Avatar
DaveJP
Is that RP Syncromax or RP ATF?
Old Dec 11, 2004 | 02:10 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
My response below is the same as another very similar question posed recently. Sorry for the double post, but wasn't sure if you saw the other thread.
I have been using synthetics in mine from my very first change at about 800 miles. I used Redline D4 ATF for about 18 months, then changed to AMSOIL ATF about a year ago. I now have something like 16k total miles, 24 SCCA races and 9 Driver's Education days on my stock tranny and it is still running strong.
AMSOIL ATF
This ATF meets DEXRON III specifications.
As a side note, AMSOIL now sells bottle pumps that screw right onto their bottles. They can be found at the bottom of the tranny or gear lube link on their online store.
Buy AMSOIL at Wholesale
AMSOIL Preferred Customer Program allows you to buy any AMSOIL product at wholesale, which is about 15-20% less expensive than retail. Cost is $10 per six months and you can buy as much oil as you want during that six months. To sign up, all it takes is one phone call to 1-800-777-7094. Give them reference number 1206638.
Or you can use this link:
Again, please put 1206638 in the customer number block.
Thanks.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Dec 11, 2004 | 03:49 PM
ZO6Les's Avatar
ZO6Les
Amsoil all the way IMHO.
Les
AMSOIL ATF
Thanks.
Old Dec 11, 2004 | 08:05 PM
Cruncher's Avatar
Cruncher
What would you think of using Mobil1 ATF? I didn't think of ot until Jim M mentioned it.
Old Dec 11, 2004 | 08:58 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Royal Purple Max-ATF
I put it in mine and it made the car much smoother feeling.
http://www.royalpurple.com/prodsa/matfa.html
Old Dec 13, 2004 | 04:08 PM
saber's Avatar
saber
I use Mobil1 ATF and when I switched shift action was smoother.
I'll also bet trans temp is lower than std ATF also
Old Dec 13, 2004 | 06:25 PM
pb24dagrk's Avatar
pb24dagrk
do you guys do a full tranny fluid FLUSH? or do you just drop the pan or what? i want to get some amsoil for mine also, but don't know how to go about it and how much to get etc.
Old Dec 13, 2004 | 08:56 PM
C66 Racing's Avatar
C66 Racing
I've been told a flush in the A4 takes about 11 quarts. If you have a Z06 or C5 with a six speed, all that most people do is a drain and refill which only takes 4 quarts. I sent you a PM with more info.
To What trans fluid
