Jacking -question
Old Dec 2, 2004 | 06:38 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Default Jacking -question
I know this has been covered numerous times, but I suppose I just want input for confidence. I'm planning on insulating the wheel wells this weekend, and am gonna start with the rear.
I've seen jacking instructions where you jack the center of the cross member between the rear wheels, which raises the entire rear end, and then support it with jack stands on either side. This just seems sorta precarious to me ... basically, you're balancing the car side-to-side on the jack until you can reach in and place the jack stands. It just seems that it might tip over.
I really have no need to get under the car ... all I want to do is get it high enough to remove one wheel at a time.
So the question is ... could I not just jack in front of and inboard of the rear wheel at that jack point? If I do this, do I need a jacking puck, or would a square of 2x6 wood be sufficient to protect the frame?
And the same questions will apply for the front when I get to that point.
Thanks.
Old Dec 2, 2004 | 06:49 AM
Patches's Avatar
Patches
Yes, you can do that but it's easy to jack from the center and place on stands, as you described. It's very stable. I've probably done it a hundred times. As long as you put safety first, it's a safe way to jack the car.
Old Dec 2, 2004 | 06:54 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Patches, I'm glad you answered because I've come to take your advice as gospel.
It looks like you have a much better jack than I do. Yours has a much larger surface area at the jacking point.
Mine's a 2.5 ton capacity, but it's one of the 'cheapies' and the jacking point surface is round with about a 3-inch diameter surface.
Would that be safe?
Old Dec 2, 2004 | 06:58 AM
Jacking from the center of the car will be much easier in lifting the car. Since you have such a small lift point on the jack, I would recommend you do what I have done. I went to a local machine shop and had them make me an 8"x8"x1/4" steel plate that I put on the jack pad to help lift the car. This plate fits very well across the crossmember and I don't have to worry about the jack not having a good lift surface. Just a thought.
Old Dec 2, 2004 | 07:11 AM
Patches's Avatar
Patches
Good advice from JD. I have used a piece of 2x10 wood to accomplish essentially the same thing as well.
Old Dec 2, 2004 | 08:37 AM
CE2004's Avatar
CE2004
I went to Lowes and bought a 1x10x24 hard oak shelf, and use it to span the rear crossmember. I must admit that I became "skittish" when lowering that down on jack stands.
Patches - wondering what your jack stands are contacting under the rear, and where?
Old Dec 2, 2004 | 09:27 AM
Patches's Avatar
Patches
Here's a shot of how we jacked a buddy's FRC with a piece of wood.
And here's where I place my jack stand supports on the rear cross member.
Old Dec 2, 2004 | 10:21 AM
CE2004's Avatar
CE2004
That's what I was looking for! You have pics of everything!
The other site I saw showed lifting the car with the board across the rear, and then lowering the board onto the jackstands. I tried this when I did my exhaust swap 2 weeks ago, and didn't like the way it felt, so I just lowered it onto Rhino's and cut the stock pipes off.
Thanks!
Old Dec 2, 2004 | 10:22 AM
97 BBB C5's Avatar
97 BBB C5
Patches, those ramps that you have in the pic under your car, can you drive the front end up on those or do they even make any that can clear the C5s front end? Inquiring minds would like to know...especially mine . TIA!
Dave
Old Dec 2, 2004 | 10:31 AM
Patches's Avatar
Patches
Dave, my car is too low to drive on ramps, even with a little pre-lift from 2x10's in front of the ramps. Btw, the black Rhino's are the ones I use. My car is lowered 1" on the stock bolts and has dropped another 3/8" since so there's no driving on ramps anymore.
I have seen "pre-ramps" at Griot's.
http://www.griotsgarage.com/catalog.jsp?&SKU=10142
Old Dec 2, 2004 | 10:50 AM
ro.co3's Avatar
ro.co3
Is there a place in the front to lift the car in the center. I'm aware of the lifting spots behind the front wheel but would love to lift from the center. Thanks for any replies.
Old Dec 2, 2004 | 11:02 AM
Patches's Avatar
Patches
You can lift similarly on the front cross member as you do the rear. You need to be careful on placement of your jack pad so as not to touch the oil pan or the drain plug. Other than that, I jack at the center of the front crossmember all the time.
Old Dec 2, 2004 | 11:30 AM
ro.co3's Avatar
ro.co3
Thanks I thought it might be ok but rather be safe than sorry.
Old Dec 2, 2004 | 11:50 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
This is really good information! I'll be trying it this weekend, with plenty of caution.
And Patches certainly has an excellent library of pictures and knowledge.
To Jacking -question
