Trunk wouldn't open
Old Dec 5, 2004 | 08:03 PM
abigfoot's Avatar
abigfoot
Default Trunk wouldn't open
The other day hit the remote open the trunk on my FRC and it popped , but I couldn't get me fingers under the lid to open it. Turned out the power latch bolts came loose and the assembly dropped down. Easy fix, but you have to pull off the license plate-backup light assy. Anybody else with hardtops or convert. have this problem?
Old Dec 5, 2004 | 08:09 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
You need this - Trunk Monkey
http://www.sillyhumor.com/trunkmonkey/
Old Dec 5, 2004 | 08:47 PM
DeeGee's Avatar
DeeGee
Yes its a common problem. I adjusted the buffers on the trunk lid which improved things.
Old Dec 5, 2004 | 09:18 PM
tdsteele's Avatar
tdsteele
DeeGee - what's a buffer?
Old Dec 5, 2004 | 09:31 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
'bout $89 for a decent one....
Old Dec 5, 2004 | 09:33 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
I was having trouble getting my fingers under the edge of the trunk lid as it would not pop up enough when I pushed the trunk button. Someone on the forum said they solved that problem by squirting a little WD-40 on the latch assembly. I immediately ran to the basement garage and applied the WD-40 and sure enough the trunk lid has popped up every time since then and that's been at least two weeks.
Old Dec 5, 2004 | 09:35 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
A little bit of oil on the hinge points will make a world of difference.
Old Dec 5, 2004 | 09:42 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
I saw the same post and it worked. As for the bolts on the latch, you don't get to them from the license plate. If you take the carpet loose you'll be able to easily acess it from inside the trunk. Just slide the assembly up and tighten the bolts good.
Good Luck!
Old Dec 5, 2004 | 10:23 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
When I can't get my fingers under the lid, I usually just take my key and pry the lid up....is that a bad thing?
I'm kidding, of course!
Old Dec 5, 2004 | 10:31 PM
Tom73's Avatar
Tom73
Of course not, could bend the key, just use a jack iron or prybar
To Trunk wouldn't open
