Correct Fuel Pressure
Old Dec 6, 2004 | 10:49 AM
TheHammer's Avatar
TheHammer
Default Correct Fuel Pressure
Does anyone know what that the fuel pressure should be in a 97? What is the fuel pressure(s) for idle in park, giving gas, etc.?
Old Dec 6, 2004 | 03:30 PM
TheHammer's Avatar
TheHammer
ttt
Old Dec 6, 2004 | 03:46 PM
Patches's Avatar
Patches
When the ignition switch is ON and the fuel pump is running, the fuel pressure indicated by a fuel pressure gauge should read 55-61 psi (380-420 kPa). The spring pressure inside the fuel pressure regulator controls this pressure. If the pressure falls below 55 psi, a lean condition could result. If it exceeds 61 psi, it may run rich. 75 psi is specified as the level at which damage could occur to the fuel system.
To Correct Fuel Pressure
