Possible PCM or BCM prob - advice needed
Oh - also the radio stops working sometimes when all this occurs.
I am speculating that I have a faulty computer unit. Would this be BCM or PCM (i am pretty sure this would not be ECM)? I am considering attempting to purchase a used computer unit an swap it out. Any thoughts on which unit I would need or any issues with swapping out to a used unit from another vehicle?
As stated previously; Check the passengers foot well under the toe board for any signs of water! VERY GOOD ADVICE!
Check the carpet, jute underlayment under the carpet and the BCM for any signs of moisture. If you find any, let me know and I will tell you how to solve that problem!
Next, my 98 was the car from HELL! I had some serious electrical issues that caused me to be stranded more times than I wish to remember. Long story short, I had corroded chassis grounds and the link below details how to solve that issue. I cleaned the grounds and just about ALL problems were fixed.
http://forums.corvetteforum.com/show...al+information
Next, remove your battery cables and clean the terminals and reinstall the terminals. Use the proper torque on the fasteners.
Read all of the codes in your DIC. After you read and copy them down, clear ALL of them and then post the results for us to review what is hapening.
PLEASE let me know if I can answer any questions to make the chassis ground connector cleaning any clearer.
Bill Curlee
