Clear Coating Engine Pieces
Old Dec 6, 2004 | 07:00 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Default Clear Coating Engine Pieces
Just finished painting some engine trim pieces, FRC ect...
Now I need to clear coat them.
Can I use a Polyurethane type clear coat, or do I need to get automotive type Clear Coat?
Tks
Peace
Willfulone
Old Dec 6, 2004 | 11:08 PM
CCA Corvette Parts
ttt
Old Dec 6, 2004 | 11:12 PM
RandW's Avatar
RandW
I'd get auto, more durable and compatible. Post pics, would like to see how your project turned out
Old Dec 6, 2004 | 11:14 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I would use a product compatible with whatever you painted the covers with. If you use the wrong type, it could lift (bubble up) the existing paint.
If you used spray cans, look for a clear in cans of the same brand/type as the paint you used.
If you used a professional automotive type finish, then use the compatible/recommended clearcoat for the paint system you used.
Old Dec 7, 2004 | 12:25 AM
PaceThis's Avatar
PaceThis
depends on what you painted it with...use the same kind as the paint you used...
Old Dec 7, 2004 | 12:49 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Mixing paints or types is not a good thing. Stick with what you have used.
To Clear Coating Engine Pieces
