x pipe helping or hurting
Old Dec 7, 2004 | 09:58 AM
steves red vette's Avatar
steves red vette
Default x pipe helping or hurting
i have a 2001 vette ,i have a blackwing filter and z06 exhuast will an x pipe help or hurt performance.
Old Dec 7, 2004 | 10:01 AM
mopac's Avatar
mopac
Default X-pipe
It should help.
Old Dec 7, 2004 | 10:06 AM
Thunder7's Avatar
Thunder7
It will provide some benefits as it has better flow (a larger hole opening than the stock H-Pipe). As far as HP numbers.... maybe 5HP? Probably less.
Old Dec 7, 2004 | 10:46 AM
jrose7004's Avatar
jrose7004
Old Dec 7, 2004 | 12:29 PM
Rou-Rou 03's Avatar
Rou-Rou 03
X-pipe should help balance exhaust better than stock cross over pipe which only has a hole about the size of your little finger
Old Dec 7, 2004 | 12:49 PM
It will smooth out the exhaust flow and perhaps make your exhaust sound a bit better. For me, since I have aftermarket cat backs, it decreased the popping when I let off the gas and eliminated much of the resonance in the car.
Old Dec 7, 2004 | 01:17 PM
OOBlackconvert's Avatar
OOBlackconvert
C5JONNY's Avatar
C5JONNY
its not a bad mod, go for it
Old Dec 7, 2004 | 03:04 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I've never heard of an X pipe hurting performance.
Old Dec 7, 2004 | 03:29 PM
yellow viking's Avatar
yellow viking
I have an X-Pipe with my full Z06 exhaust system. With the H-pipe replaced by the X, there is no deceleration popping and the exhaust note is a little deeper and smoother. I also have a Blackwing with a hi-flow air bridge and 3:42's and dyno'd 324rwhp. I am sure the X-pipe helped.
To x pipe helping or hurting
