changing oil
Old Dec 8, 2004 | 05:14 PM
jan55's Avatar
jan55
Default changing oil
Has anyone used one of the oil change pump systems to change the oil in their car? I see them advertised and it would be nice not to have to jack up the car to do this...but do they work? If they do, which ones would you recommend.
I would like to do this myself but do not like the idea of jacks and jack stands, etc.
Thanks to all who reply.
Old Dec 8, 2004 | 05:22 PM
DaBoz's Avatar
DaBoz
Jiffey Lube might be your answer!
Old Dec 8, 2004 | 05:40 PM
REDRWUT's Avatar
REDRWUT
I wouldn't do that. There will be sludge left in the pan that would normally drain out with the plug pulled.
Old Dec 8, 2004 | 05:42 PM
WEF's 95's Avatar
WEF's 95
If this is the type that goes into the dipstick.....don't bother. It's convenient for a boat or a skidloader but it cannot remove all the oil.
Old Dec 8, 2004 | 05:43 PM
cob206's Avatar
cob206
St. Jude Donor '05-'06-'07-'08
You still need to jack it to change the filter. Some members use those quick lube joints and bring their own oil and filter. Maybe that would be a better option for you.
Easygoing's Avatar
Easygoing
I agree, I don't think you would get all of the old oil out with a pump. You need to get under the car anyway to change the filter, so you might as well do the drain plug method. I have used a pump on my boat and they do work pretty well though, but I would not use one on my Corvette.
Old Dec 10, 2004 | 06:56 AM
Patman's Avatar
Patman
Just get a set of rhino ramps for $20. The C5 will drive right up them very easily (unless it's lowered more than stock) and you'll have tons of room to work under there.
Old Dec 10, 2004 | 08:20 AM
Mark S.'s Avatar
Mark S.
As stated before...you will still have to get under to change the filter (then you will have to jack up the rear to get all the oil out).
Old Dec 10, 2004 | 08:26 AM
CE2004's Avatar
CE2004
Yeah - they are for changing the oil on boats and applications where you can't do a gravity drain... If you're not comfortable under your car, on Rhino's or jack stands, take it to a professional for an oil change.
Old Dec 10, 2004 | 12:57 PM
I would not use this method to change oil. If you don't feel comfortable doing it yourself, take it to a dealer or a competent oil change facility to do the work.
Old Dec 11, 2004 | 10:23 AM
jimcork1's Avatar
jimcork1
Default Rino Ramps?
Where do you get the rino ramps. I use the pucks,, jack and block to insure level. The slightly jack the rear to all oil to drain for 30 minutes. I have never seen ramps low enough for the air dam to clear. vettdvr 99 Nassau Blue
Old Dec 11, 2004 | 10:34 AM
Tom/99's Avatar
Tom/99
Di it yourself, then you will know what, is being put into your car. At the oil change places, you never know what they are putting into your car.
Old Dec 11, 2004 | 10:42 AM
89convt's Avatar
89convt
I don't like using the ramps because it causes the pan to slope towards the front and leaving a amall amount of oil that won't drain. I live on a culdesac without much traffic. I back it into the drive, place the tires on the front side of the curb gutter and use the gutter for me to crawl into and access the plug and filter. And just hope my neighbor doesn't start to was his car about the time i start my oil change!
Old Dec 11, 2004 | 12:01 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
It's really not that hard to change the oil. The first time is always the hardest. But after you know whats required it's not that bad. Plus what ever equipment you get it'll be used for many other projects and mods. My .02
Old Dec 11, 2004 | 12:10 PM
sharpvet03's Avatar
sharpvet03
Old Dec 12, 2004 | 07:12 AM
Patman's Avatar
Patman
Autozone, Walmart, Pepboys, etc. About $20 or so. Be sure to get the gray ones, not the black ones. (the gray ones have a higher load capacity)
Old Dec 13, 2004 | 01:59 PM
jthoresen's Avatar
jthoresen
I use a pela oil pump on my VW jetta diesel (the oil filter is on top). But I won’t use it on my C5.
To changing oil
