Dynamat install
Old Dec 8, 2004 | 08:07 PM
CUlookin's Avatar
CUlookin
Default Dynamat install
Hey guys, I'm about to install a bunch of stuff on my car and I figure while I have it all torn apart, why not install dynamat Xtreme throughout my passenger area (under seats, doors, and torq tunnel). I was wondering if you guys had any suggestions in tems of how to remove the carpet, how to do the doors, or other simple hints to help me out. I already have the KY out so no bend over jokes please
Old Dec 8, 2004 | 08:15 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
First get ready to shell out about $800 for the Dynamat extreme.
Then go to the tech center and look up "noise reduction", there you'll find instructions on how to install Frost King and Reflectix insulation. The procedure is the same, just a lot less money.
Old Dec 8, 2004 | 08:31 PM
scott_fx's Avatar
scott_fx
check out this link and do a search, there was a huge thread about doing this.
I plan on doing some of this when i install my car pc this winter :-D
http://forums.corvetteforum.com/showthread.php?t=962119
Old Dec 8, 2004 | 08:42 PM
fmpros's Avatar
fmpros
I'm probably missing something but why spend so much money? I picked up a water heater jacket at Home Depot, 20 bucks a roll (one roll did half of the trunk, I'll probably use 3 rolls for the trunk and cab), it has the aluminum foil on one side and a nice insulating padding on the other. It cuts easy, tapes easy and does the trick. Also, it doesn't say "HAZARD, WEAR APPROPRIATE BREATHING APPARATUS WHEN HANDLING. MAY CAUSE CANCER" on the label. Do I want to be surrounded with that while I drive in my car 4 hours per day?
Old Dec 8, 2004 | 08:48 PM
CUlookin's Avatar
CUlookin
actually, 800 bucks is a bit steep. I got 32 sq. ft. of Dynamat Xtreme for like 80 bucks on ebay. At the most, I would need three 32 sqft. kits for the entire car, but I'm only doing the cabin. Thanks for the info guys
Old Dec 8, 2004 | 08:56 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
dynamat is the way to go for sound deadening for car stereo setups to stop rattling and add weight to things to raise their resonating freq.
The stuff at the hardware store will do the trick for road noise.
all you really need to do for that is apply it over the rear tire area and you will have done the trick.
Old Dec 8, 2004 | 08:59 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
CULookin, maybe we can have a dynamat extreme party... i live in Gaithersburg, and have 32 sq ft sitting in my garage as well
From everything i've read, people here seem happy with a frost king solution. Also, it seems you need more than 32' to do the whole car. In my case, I plan to partition off the back, so I'm only concerned about everything from the partition forward.
Let me know if you want to get together for a day to rip our cars apart
Old Dec 8, 2004 | 09:03 PM
EatRice's Avatar
EatRice
Anyone in the Florida/Georgia area planning on doing noise reduction in their vette? If so let me know so we can test out these two methods properly.
Old Dec 8, 2004 | 09:04 PM
JohnTheStigGalt's Avatar
JohnTheStigGalt
Don't know about the Dynamat Extreme, but the regular Dynamat weighs a TON!!! I lined a computer case with it to cut down the noise of a very loud computer fan required for this uber-chip I was using -- Wasn't a lot of mat, but it made the case REALLY HEAVY!!! Would never put that in a performance sports car... Maybe the Extreme is lighter.
Old Dec 8, 2004 | 09:08 PM
Ken King's Avatar
0Ken King
Former Vendor
CF Pit Crew
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05
I used 2 of the 32' box's with only a little left over.
Everything from the seats back will give you the best overall improvement in sound.
Ken
Old Dec 8, 2004 | 09:50 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I also used Dynomat Extreme. I stripped out the entire interior and also both doors and used 3 bulk packs of the stuff. It was a pain in the the butt to do but made a huge difference in sound quality of interior.
I paid a total of $350 for all three packs.
Old Dec 8, 2004 | 09:56 PM
mavrick331's Avatar
mavrick331
I used the same stuff in my 73' worked great!!
Old Dec 8, 2004 | 09:57 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
i would like to spectate on that as well, and i am sure that my buddy with his z would like to see how its done too.
Old Dec 8, 2004 | 10:22 PM
CUlookin's Avatar
CUlookin
99C5Vert, I'm actually putting in Ken King's interior in my 04 vert next wednesday, and I figured while I was already gunna be in their for 6 hours or so (I got a Hurst Shifter and gauge bezels to install too), I might as well just rip it all down and go to town on the Dynamat. As I said, I'm doing it next wednesday so you're welcome to come down and join the party!
Old Dec 8, 2004 | 10:25 PM
Mike Mercury's Avatar
Mike Mercury
keep in mind that the alternatives were used for 2 key reasons:
1. weight (lack of)
2. Price (lack of also)
if adding weight is not a concern for you, and the price of the Xtreme offering is not a turn-off either, then I would suggest going with the better performing Xtreme material.
To Dynamat install
