I am also going with the Supermaxx system too, 10 rwhp I'm not impessed, although they all claim 35 - 40 rwhp which I don't believe, I am already at 312 rwhp with a A4, blackwing & Borla's will see what I'll get when I install the supermaxx system. I'll be happy if I get half of what they claim.
I actually think you did pretty good. If you look at your final number, it is right in line with a header installation, maybe a tad low. I am at about 330 HP with headers, but I also have a very conservative tune.
I didnt get an AF print out but they hooked it up and it was a constant 11.9, for the second run, and dipped down to 11.7, then back to 11.9 for the 3rd, they say with a tune getting it up near 12.5 could get some more HP.
Mine is sitting right at 12:1. The car will lean out on the street, so don't go too lean on the dyno. You are right where I am with the tune as far as AFR and our numbers are very similar so I think you are where you should be. I don't think you will get a ton more HP if they lean it out, but maybe 5-10, just be careful of the final AFR.
10-15 rwhp is not much of a gain for what you spent. At this point I would stop buying expensive bolt on's and go straight to the Cam, valve springs and tuning for a real boost in RWHP. You will like the results much better IMO.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
That is kind of low to me too.
That is one of the reasons I went straight to a blower and bypassed other bolt ons. If you figure that headers cost you ~$2000 (with install, dyno and tune), and H/C might be in the ~$4000 range (or thereabouts) and a blower in the ~$8000 range...
I'm waiting to dip DEEP into my engine before I crack it open - forged crank, rods, pistons, springs, valves, heads, cam, intake, oil pump - everything when I do touch it. Or maybe go all out with a 427 (if I can afford it!!!).
Headers are on my bolt on list - but 3.73:1 gears and a higher stall are money better spent (for me) - I have a A4.
But nice mod all the same. Hey, ANY mod is a nice mod.
cam is def on the list, just wanted to get the basic crap done first, I did expect more from the long tubes cat and X, I am happy that the gain was across the curve not just peak numbers, thinking about a 581/224 114 cam, still dont know if I want to go bigger for more HP, and of course the tune.
You picked up good power WITHOUT a tune. The car is pig rich. Those long LT's like to run on the lean side. Figure out where you want to go with the car........... head & cam, blower, n20 or whatever and do it once with a final tune. You will be very surprised at the results. Dynatech makes a very good header system, and when you factor in the price, I think it's the best deal out there for LT's. You MUST tune the car.
i have had nothing but problems with my supermaxx's...my car stalls every other day now. Chevy saw the code, and it was for a heated o2 sensor perf left 1 bank 1...seems the o2 sensors are further down the pipes then stock and so they don't read correctly and aren't speaking to the computer right!
That is not a "header" problem. If your taking advice from the dealer, thats your first mistake. Are you sure you routed the o2 wires properly? Did you cross the fronts???????? Thats the first thing I would check before placing blame on the header. What was the specific code?????
Has your combo been competently tuned? Your figures seem low for your combo.
I would get the car up and make sure the front 2 are not crossed myself, that was my prob to begin with, also if they codes say its the rear sensors, just get the sims.
