Wheel Balancing
Old Dec 13, 2004 | 12:33 AM
jhanwell's Avatar
jhanwell
Default Wheel Balancing
Recently bought an 02 coupe and need some advice. I want to get an alignment done and have all wheels balanced. What is the best way? Static balancing or dynamic? I hate wheel weights on the outside of the rim. Thanks!
Old Dec 13, 2004 | 05:15 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Dynamic balancing is the only method that I know of. They take the wheels off the car, put it on a machine that spins the wheel and tire up to speed, and the machine indicates where and how much weight is needed. After attaching the weights, they spin it up again to make sure it's balanced. It also indicates whether to put weights on the outside or inside of the wheel. You can opt for stick-on weights that are put on the inner surface of the wheel, or for clip-ons that are put on the outside or inside or both.
There used to be an 'on the car' dynamic balancing which used a machine that somewhat resembled a large floor jack that was placed in contact with each wheel that would spin it up. I haven't seen that used in many years.
I doubt that you can even get a tire/wheel static balanced any more, or at least the kind I remember. They'd take the wheel off, lay it horizontally on a machine, and balance with a built-in bullet-type spirit level by trial and error. I'm fairly certain that is from the long distant past.
Old Dec 13, 2004 | 06:50 AM
Dynamic balancing has always worked for me. I have them use stick on weights to the inside so I don't have those unsightly weights on the outside of the rims.
Old Dec 13, 2004 | 06:53 AM
Z0SLIK's Avatar
Z0SLIK
I'll second that!!
Old Dec 13, 2004 | 07:22 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Dynamic balancing for me including lateral. Preferrably on Hunter equipment.
Old Dec 13, 2004 | 09:46 AM
jhanwell's Avatar
jhanwell
Default Balancing
Thanks Guys!
Old Dec 13, 2004 | 09:54 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
A friend of mine is having his balanced and what they are going to do is. Spin them and determine what weight is required and then unbead the tire and put the weights on the inside of the tire. So that there are now weights showing at all. Sweet.
Old Dec 13, 2004 | 12:26 PM
Pumba's Avatar
Pumba
Ed,
Your friend is stupid.
Once you break the bead seat on a tire wheel assembly you destroy the ability to accurately balance it.
Old Dec 13, 2004 | 12:54 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Most of the better shops selling performance tires and wheels will have the Hunter 9700 Road Force balancing equipment. If they don't - go somewhere else!
Old Dec 13, 2004 | 01:45 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I just had mine balanced w/ this machine. It's the only one that stopped the slight shimmying I had...
To Wheel Balancing
