C5 Billet Ac Knobs
Old Dec 15, 2004 | 03:27 PM
bbaarrrryy's Avatar
0bbaarrrryy
Former Vendor
Default C5 Billet Ac *****
CHECK OUT
www.ssinserts.com
New C5 AC *****
Old Dec 15, 2004 | 03:40 PM
Flyskate's Avatar
Flyskate
Definately cool! I would buy billet ***** if they were available for the manual hvac *****.(like the mustang shown)(hint hint!)
Old Dec 15, 2004 | 03:57 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
...need tuner ***** too...
Old Dec 15, 2004 | 04:33 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Will those go with EnglandGreen's neon licence plate surround?
Old Dec 15, 2004 | 11:12 PM
ZBrink's Avatar
ZBrink
St. Jude Donor '06
Tuner ***** would be great. Also, they have great prices on shift *****!
Old Dec 16, 2004 | 01:19 AM
LoneStarFRC's Avatar
LoneStarFRC
Check out www.uprproducts.com
They have billets for man HVAC on GM trucks. With some modification they can be made to work fine on C5's. Basically you have to drill the hole out slightly to get rid of the "D" shape, re-install the little spring steel "D" insert 180 degrees different from the way they come installed then epoxy it back in. Next, the the "shoulders" or "stops" on the rear of the ***** have to be narrowed a little in order to fit into the "windows" behind the *****. These determine how far right or left the ***** are allowed to turn. A drill, a Dremel, some epoxy and a little time are all that's needed. Of course once modified, the ***** are non-returnable.
I like mine. I got the ones with the blue lens inserts. They go good with my billet shifter **** and parking brake handle.
Old Dec 16, 2004 | 01:52 AM
F.J.B.'s Avatar
F.J.B.
From: Vette Doctors Performance RX450 - 466RWHP !!!
Thats a site I will have to visit after the holidays.. The wife would kill me if i buy more stuff before xmas!!!!!!!!!
Old Dec 16, 2004 | 01:55 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Now was that nice to pick on EnglandGreen that's my job
The ac ***** look great.
Old Dec 16, 2004 | 02:38 AM
intel55's Avatar
intel55
looks
would also like to see the manual ***** come out.
Old Dec 16, 2004 | 02:42 AM
LoneStarFRC
Originally Posted by intel55
looks
I e-mailed UPR Products and told them how my modifications would allow them to offer the three ***** for C5's with manual HVAC. Even gave specifics on dimensions etc. No response. Nada.
Old Dec 16, 2004 | 11:36 AM
intel55's Avatar
intel55
I might order those a follow your mods and see where it takes me
Old Dec 16, 2004 | 11:55 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
@!@#$!#@! Just ordered the AC ***** and Aluminum shifter ... I hate coming to this place so early in the morning ... "The Force" is too strong to resist! :
BTW, I'm gonna change the green to cobolt blue when I get em! PIx to follow ....
Old Dec 16, 2004 | 12:09 PM
LoneStarFRC
Look closely at your factory ***** and take a couple of measurements if necessary. When removing the material from the "shoulders", be sure to take an equal amount from each side. Done properly, this will allow the "pointer end" (the end with the lens) to point correctly at the marks on the HVAC unit when the **** is rotated all the way to the left or all the way to the right. Also, when re-installing the little spring steel insert in the hole on the back, make sure and only use a very very small amount of epoxy and let dry. You don't want any epoxy oozing out into the hole itself and making the hole too small to fit onto the shaft or worse, epoxying the **** onto the shaft. Then you wouldn't be able to remove the ***** in the future as it would be bonded to the shaft. Take your time, use a little common sense and check you work as you go. It's really not as hard as it may sound here. HTH
Old Dec 16, 2004 | 12:40 PM
WaWaTuSi's Avatar
WaWaTuSi
St. Jude Donor '05
Anyone have a picture of something like this installed?
Old Dec 16, 2004 | 01:04 PM
LoneStarFRC
Unfortunately, for me, I don't have a digi cam. You can however go to upr website and look at the ***** on some GM trucks. Their HVAC control head panel display is identical to the C5 with manual HVAC. HTH
Old Dec 16, 2004 | 01:05 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Just covering your six.....
Old Dec 16, 2004 | 02:09 PM
LuS1fer's Avatar
LuS1fer
UPR's 1997-2004 C-5 Corvette Billet A/C **** kit is the one of the cleanest billet kits you can add to your Corvette's interior.
These new additions to our billet line are just the beginning of many items to come for the 97-04 Corvette interior.
Our new A/C ***** have an illumination hole to ensure proper position in day or night.
Think I prefer the smooth ssinserts version.
To C5 Billet Ac Knobs
Old Dec 16, 2004 | 02:23 PM
LoneStarFRC
The only problem, as I see it, is that the ***** being offered for the C5's are for the automatic HVAC control panels (two **** set). Without modifying them, the other ***** offered for the GM trucks will not work on C5's with manual HVAC (three **** set).
Old Dec 16, 2004 | 02:27 PM
T's's Avatar
T's
St. Jude Donor '06-'07-'08
I'am with ya
Old Dec 16, 2004 | 02:52 PM
intel55's Avatar
intel55
THanks for the tips, will follow
Ordered today.
