Warm-up?
Dec 15, 2004 | 08:14 PM
Warm-up?
How long do you let your car warm-up before you drive?
Dec 15, 2004 | 08:28 PM
I turn the key to on and let the guages peg and go back down, then start the car and let the oil pressure get to operating pressure, put it in gear and go!
Dec 15, 2004 | 08:37 PM
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
I'll do the above but I'll also drive very moderatly the first few miles until my oil temp is at least 145 degrees. By then, all the other fluids are at proper operatinig temperatures as well and going wide open will not hurt anything.
Dec 15, 2004 | 08:38 PM
always drive moderately till the oil temp gets to about 120 then let her rip
Dec 15, 2004 | 09:09 PM
St. Jude Donor '06-'07-'09-'10
A Vette is like a woman. Needs to be warmed up to perform well.
Dec 15, 2004 | 09:25 PM
After starting, I drive it fairly easy until the engine has warmed sufficiently.
Dec 15, 2004 | 09:29 PM
I let the temp hit 100 before moving, just a habit for me.
Dec 15, 2004 | 11:10 PM
Probably 15-20 seconds, just enough to get the oil pressure up. After that, I take it easy until it gets up to temp.
Dec 15, 2004 | 11:12 PM
St. Jude Donor '11
Quote:
...I have been agreeing with JD a lot lately because he has been making good sense
Dec 15, 2004 | 11:43 PM
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
Dang, did not know about this warm up, 145 & so on !
Will give it a try
Dec 15, 2004 | 11:47 PM
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Dec 16, 2004 | 05:52 PM
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Depends on how many things I forget inside the house ... usually a minute or two.
Dec 16, 2004 | 05:56 PM
From: SCMR Rat Pack'r Charter Member..Great Bend KS
It takes your car that long to build oil pressure????
By the time you depress the clutch and snick it into first it should be ready to rock.
Larry
Dec 16, 2004 | 06:06 PM
I let it warm up till the temp gauge (far left one) starts to move
Dec 16, 2004 | 07:41 PM
Quote:
There has got to be a mod to fix this problem.
Dec 16, 2004 | 10:15 PM
2-3 mins. With the h/c setup I feel it is critical to make sure the fluids are moving well and things are quite warm. I also drive conservatively until the tranny temp gets above 120-130.
Dec 16, 2004 | 10:21 PM
Dec 16, 2004 | 10:28 PM
Dec 16, 2004 | 10:29 PM
Quote:
Dec 16, 2004 | 10:31 PM
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Start it take it easy till the oil temp is up and let her rip.
