Battery life
Old Dec 17, 2004 | 03:54 AM
furio666's Avatar
furio666
Default Battery life
HI there I just wanted to know how long A stock batery should last if you don't start the car for a while my car is a 2003
Old Dec 17, 2004 | 04:10 AM
jdmvette's Avatar
jdmvette
Night Owl for life
why aren't you driving it
well seriously it should last at least a couple years, but i'd yank it right away due to the fact that it may leak and ruin very expensive components that are underneath it.
Old Dec 17, 2004 | 04:34 AM
furio666's Avatar
furio666
Stored for the winter
Old Dec 17, 2004 | 04:37 AM
jdmvette's Avatar
jdmvette
Night Owl for life
if you have it stored then why not keep the battery out of the car on a trickle charger that way there's no chance of leaks and you'll know that the battery is topped off and ready when you need it.
Old Dec 17, 2004 | 07:01 AM
Welcome. I agree with the above - if you have it stored, I'd take the stock battery out and put it on a trickle charger. The stock battery is known for leaking and with a computer and wiring sitting right below the battery tray, it is not worth the chance. Just be sure to remember your radio theft lock code if you do this.
Old Dec 17, 2004 | 07:46 AM
Deluxe's Avatar
Deluxe
St. Jude Donor '06 thru '16,'22,'24
The '03 uses a gel-type battery. Not as likely to leak, but more prone to a short life (pun intended). I replaced mine with a Red-Top when I noticed it took an extra turn or two on the starter before the engine would fire. Didn't bother with warrenty... the Red-Top will outlast the replacement too.
Old Dec 17, 2004 | 08:38 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I agree that a leaking battery is not something that you should expect with a 2003. However, I would not suggest removing the battery and putting it on a trickle charger - I would suggest leaving the battery installed and using a Battery Tender type of charger - it will keep the battery charged throughout the winter for you. Many of us use them without any problems - even under car covers.
Old Dec 17, 2004 | 08:40 AM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
This one with. The AGM should not leak, and as long as it is kept fully charged, should last quite a while.
Old Dec 17, 2004 | 09:17 AM
hhntr111's Avatar
hhntr111
I agree...I've got my 2004 under a cover in the garage on a battery tender. I take it for a drive on nice days in the winter, and the amazing thing is that when I hook up the tender, right after shutting down, it starts to charge. The car fires right up next time. A tender is the way to go.
Next spring, I'll probably get an Optima.
hhntr111
Old Dec 18, 2004 | 02:14 AM
GrayC5's Avatar
GrayC5
Beginning sometime early in model year 2001 through model year 2003, AC-Delco Absorbent Glass Mat (AGM) batteries were installed in the C5s at the factory, not gel-type batteries. There is a difference between the two. See Absorbent Glass Mat (AGM) and Gel-Cell Battery at this link: Tech Talk: Battery Terms
Optima batteries also use AGM technology.
And here's some more info on the AC-Delco batteries from C5 Tech Tips section of the Forum: 1997 - early 2001 Battery Acid Leakage Issue
My understanding is that AC-Delco has discontinued their AGM batteries.
Old Dec 18, 2004 | 11:24 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
From what I read, with the Vette's parasitic draw the battery will last about a month on its own before draining down with out starting. A battery tender is recommended if you let it sit for long periods. The battery tender differs from a trickle charger, a trickle charger always sends current to the battery even if it is fully charged. The battery tender will stop charging once the battery if fully charged and only start charging again when needed. This is safer and better for the battery.
To Battery life
