2001 Directional Problem
Old Dec 17, 2004 | 09:49 AM
kenb538's Avatar
kenb538
4th Gear
Default 2001 Directional Problem
My directions have been working intermittenly for about 6 mos. Everytime that I take the care to the dealer, they are working fine. Any experience with this problem.
Old Dec 17, 2004 | 10:11 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Yep, you need to have the 4-way hazard switch (next to the center duct) replaced. Common failure- do a search and you'll find that quite a few of us have had this problem. Sometimes, when the turn signal doesn't work, you can press the 4-way hazard switch and it will temporarily reset the turn signal until the next time it decides not to work. Replacement is covered under warranty.
Old Dec 17, 2004 | 11:37 AM
bpc4me's Avatar
bpc4me
I had this same problem and GM is well aware of it. Sounds like they don't want to fix it. When I first took it to them they said they couldn't replicate the prob. After posting on the forum and being better informed, I told them when I hit the hazzard switch it works. Mechanic told me " Yeah, that's a comon problem with Corvettes".
To 2001 Directional Problem
