strange problem???
Old Dec 17, 2004 | 09:55 AM
dr.nick2's Avatar
dr.nick2
Default strange problem???
Have any of you noticed this possible problem;upon first unlocking your car,then entering your car,stick key in ignition,close door,seat is suppose to move to its memory position,but only moves halfway ,
then when you do it again,it goes to its proper memory position
I don't know what to make of this.P.S.during the course of the day,in and out,it works properly it only does this when I initally enter the car.
Old Dec 17, 2004 | 09:59 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
yes, we have seen this also - I try to be careful that when I put the key in, I do it in one clean motion and that it is firmly installed. That usually makes it work fine...
Old Dec 17, 2004 | 10:00 AM
RENO's Avatar
RENO
You will also notice that sometimes the easy entry option doesn't work. That is, the seats don't move back when you take the key out. It also seems to be related to the timing between shutting off the ignition and removing the key.
Old Dec 17, 2004 | 11:40 AM
bpc4me's Avatar
bpc4me
lol, now that it's mentioned I get this too. Never even thought about it.
Old Dec 17, 2004 | 11:41 AM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
Happens quite often here...
Old Dec 17, 2004 | 11:45 AM
srchief100's Avatar
srchief100
YES - Same here
Has happened about twice. However since I've been careful about the key insertion - no more problems
Old Dec 17, 2004 | 11:46 AM
girl-ina-box's Avatar
girl-ina-box
St. Jude Donor '05
I get that too! Usually when I'm in a hurry...
Old Dec 17, 2004 | 03:02 PM
ROD BROWN's Avatar
ROD BROWN
Default Me to!!
Don't know why,but it does happen occsionally.One of the quirks related to these cars.
Old Dec 17, 2004 | 04:14 PM
Mine has done this before - but only on occasion. Just one of the things I live with.
Old Dec 17, 2004 | 07:26 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Mine reacts a little different. Sometimes I'll move the seat back before
I get out and when I hit the unlock button the seat moves to memory
position before I get in. Have i programmed wrong?
Old Dec 17, 2004 | 07:52 PM
Derek Byrne's Avatar
Derek Byrne
Same thing happens to me, When I press the memory button again it goes all the way forward ,will be carefull of the key insertion from now on
Old Dec 17, 2004 | 07:57 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
All the tume. Eventually stopped using the easy entry option because it was a PITA.
Old Dec 17, 2004 | 08:35 PM
diyguy's Avatar
diyguy
After experimenting around, I found (at least in my case).. a way to make it work everytime.
Get in your car...Close the Door FIRST, then stick the key in the ignition. While your seat is adjusting, get clipped in with seat belt. By the time thats all done, your seat, mirrors, temp and radio are all set, ready to turn the key.
Might try that sequence, as it frustrated the hell out of me, until standarding the same procedure every time.
Works for me.
Old Dec 17, 2004 | 08:39 PM
diyguy's Avatar
diyguy
Oh, on the reverse side, when you shut the engine off, pull the key out, BEFORE you open the door, then the seat will retract fully for easy exit.
Might try that too.
Old Dec 17, 2004 | 09:24 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
I think we've all got that one! Just a Vette quirk! Zuti
Old Dec 17, 2004 | 09:50 PM
redride42's Avatar
redride42
I had the same problem and I took it back to the dealer. They replaced the seat mechanism. Haven't had any trouble since.
Old Dec 18, 2004 | 08:55 AM
JUSAKD's Avatar
JUSAKD
I'am 5ft2 my son is over 6ft. He got in with the seat back. Put in the key. The seat went all the way forward. Almost put his knees tru the bolsters on the dash. He very vocal as the seat pinned him in. I was
To strange problem???
Old Dec 18, 2004 | 09:04 AM
bipp>C5's Avatar
bipp>C5
I was worried about all the travel the seat, telescoping steering and whatnot moving each time I get in and out. Instead of auto seat on/off
I program (2) to be my primary seating and (1) just ever so diffeant, basically enough to get legs out so that the overall travel of seat is just forward a bit and back a bit not changing every seat option. Hoping for less wear and tear. OH so the reason for this is when you unlock the car remotly the seat moves to (1) and you have enough room to get in and then (2) as you buckle in. Probably but......
Old Dec 18, 2004 | 12:17 PM
DeeGee's Avatar
DeeGee
I think mine has Alzheimers!
Old Dec 18, 2004 | 12:24 PM
JohnTheStigGalt's Avatar
JohnTheStigGalt
I've been meaning to ask this question for a while. Glad it's not just me...
