Help... what causes code p0410?
Old Dec 19, 2004 | 11:16 PM
Vette 4 Fun's Avatar
Vette 4 Fun
Default Help... what causes code p0410?
I have a 2001 Vert (with Stingers on both ends -which may, or may not have anything to do with it.) but I gotten a "10PCM P0410 H C" check engine light twice now in about 1 month, 600 or 700 miles a part??? Any ideas on what it could be?? Thanks!!
Old Dec 19, 2004 | 11:28 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
P0410 AIR System
http://www.stengel.net/diccodes.htm
THe AIR system is only active upon first starting a cold engine. Check the hose connection at your Stinger intake. Make sure the hose is snug on the elbow, and that neither are cut/cracked.
Old Dec 19, 2004 | 11:34 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Found this on another forum it may help
P0410 indicates the A.I.R. (Air Injection Reaction) pump is not working properly. This is an electric pump that's located inside the front fascia on the drivers side. You should be able to hear it running when you start the car. It may be as simple as a blown fuse (The fuse for this pump is located in the engine compartment fuse panel)
Old Dec 20, 2004 | 12:12 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
As the weather turns colder your AIR system check valves can stick shut and cause that code. You can take them off and spray them out with carb cleaner. I just had them replaced under warrenty on my 02 ZO6. So far so good!
Old Dec 20, 2004 | 01:07 AM
Vette 4 Fun
Do you know which fuse?? Thanks!
Old Dec 20, 2004 | 03:49 AM
Zilla's Avatar
Zilla
Could be but not sure a micro relay number 33 under the fuse cover in the engine compartment
Old Dec 20, 2004 | 10:30 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
http://forums.corvetteforum.com/showthread.php?t=971880
Old Dec 21, 2004 | 02:13 AM
Vette 4 Fun
Thanks!!
Old Dec 21, 2004 | 02:14 AM
Vette 4 Fun
Thanks for the link!
To Help... what causes code p0410?
