Clean Engine?
Old Dec 20, 2004 | 11:35 AM
adg's Avatar
adg
Default Clean Engine?
[FONT=Verdana]Looking at all the clean and shiny engines out there makes me wonder how you guys do it.
Do you just get under the hood with a cloth, or are you using some cleaners and/or chemicals?
Old Dec 20, 2004 | 11:53 AM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
I use my shop vac with a soft brissle dusting brush on it to clean the grit and dust that is accessible then I take my air compressor hose with a jet tip on it and blow all the areas the vac doesn't get. I then go back over with the vac to pick up any debris brought out by the air hose. It you have fluids getting out that should be addressed immediately. Thankfully I don't, but my '02 has only 8500 miles. I am not one who sprays water under my hood. I may take a damp rag under there but certainly not a water hose.
Old Dec 20, 2004 | 12:02 PM
6 speed Sid's Avatar
6 speed Sid
I am sure you will find some that disagree, but I never spray and liquid under the hood. Use air and wipe down only.
Old Dec 20, 2004 | 12:08 PM
VetteSiNz's Avatar
VetteSiNz
I clean the engine compartment after I wash and wax the car. I also use damp terry towel and use a paint brush (sponge) hard to reach area.
Old Dec 20, 2004 | 12:11 PM
Busa196's Avatar
Busa196
I use a rag with some "Aerospace 303" (similar to Armorall but not as greasy) and an air compressor. If you maintain it, you won't need to use water.
Old Dec 20, 2004 | 12:27 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Don't forget the hood seal mod, helps with the up keep.
Old Dec 20, 2004 | 12:56 PM
LivinTheDream's Avatar
LivinTheDream
Check out the latest Corvette Fever mag. There's an article on cleaning the engine compartment of a C5.
To Clean Engine?
