Thninking About Lowering?
Old Dec 21, 2004 | 10:53 AM
BLACK02's Avatar
BLACK02
Default Thninking About Lowering?
I'm thinking about lowering my vette. Is there anything that I should consider before doing this? I do not have headers yet, but thinking about Lt's in the future. What is the ballpark cost to get this mod done?
Thanks.
Old Dec 21, 2004 | 11:02 AM
spiral04vette's Avatar
spiral04vette
From: Los Angeles I'm here for a good time, not a long time!
I lowered mine about a month ago, and I have loved it since. And it cost me all of $NOTHING, zero, zilch, NADA. Look up lowering in the Tech portion and you will find exact photos of how to lower your vette. It takes all of about 20 minutes, start to finish.
Heck, if you live in So Cal, come over I'll od it for you.
I dropped mine about 1.5 inch in the back and about 1 in. in the front.
Enjoy,
Old Dec 21, 2004 | 11:04 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
https://www.corvetteforum.com/techti...D=27&TopicID=1
Easy to do. Think about getting a 4 wheel alignment after lowering. It's a good idea.
Old Dec 21, 2004 | 11:08 AM
NSTG8R's Avatar
NSTG8R
did mine in the drive way the other day.
good mod. only prob is i scrape the sh*t outta everything now.
oh well, the black pieces only cost $15
Old Dec 21, 2004 | 11:51 AM
jrose7004's Avatar
jrose7004
Lowered mine in March and haven't had any problem!
Old Dec 21, 2004 | 12:10 PM
jdplays's Avatar
jdplays
how important is the wheel alignment? does the car not drive straight after, or does it just wear out the tires quicker?
Old Dec 21, 2004 | 12:15 PM
roscoe118's Avatar
roscoe118
Well, it will definitely be one, or both, of these. And with the cost of tires for these cars, it would be $70-$80 well spent
Old Dec 21, 2004 | 12:21 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Great MOD and easy to do. Takes about 1.0 hours with taking your time and learning more about your car.
Patches has some great pics around here somewhere. Search the message board for "Lower" and you should find the pics.
Old Dec 21, 2004 | 12:47 PM
Only thing I can think of is you have to be careful where you drive the car. Steep driveways will result in scrapes and speed bumps will have to be negotiated carefully. Other than that, the look is
Old Dec 21, 2004 | 12:55 PM
LowFlight's Avatar
LowFlight
St. Jude Donor '03, '17
Senior Member
Cruise-In V Veteran
with regards to alignment...the rear was still in alignment and the front was BARELY out...the guy did not want to fool with it, but I insisted he adjust it well into the green just to be safe. All and all, it was not out much if any.
Old Dec 21, 2004 | 02:50 PM
Glennm27's Avatar
Glennm27
Every car is different & every situation is different. Some need alot of correction after lowering some very little, some NONE.
Some need alignment even BEFORE lowering.
Some cars could use an alignment right out of the dealers showroom.
You never know.
Anytime the geometry of the suspension is changed, the alignment is also changed.
Going from OEM C5 rims to CCW's for instance should also call for alignment, or at least a check of the alignment.
Old Dec 21, 2004 | 02:54 PM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
Do it - and if you do find yourself scraping alot,
order these (mine should be in this week):
Frame Savers and Rocker Rails:
--THIS MONTH'S SPECIAL--
Reduced prices on Frame Savers, Rocker Rails, and Frame Saver / RockerRail Combo
Save an additional $20.90 with the Rocker Rail - Frame Saver Combo $109.00
https://www.aandacorvette.com/cart/s...sp?MainCatID=5
Old Dec 21, 2004 | 03:03 PM
scott_fx's Avatar
scott_fx
This car is meant to be lowered It looks a lot better then the 4x4 stock look.
Old Dec 21, 2004 | 03:33 PM
Dale98C5's Avatar
Dale98C5
Frame savers and rocker rails are a great investment!
Old Dec 21, 2004 | 03:40 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Haven't had mine lowered, but do have some A&A framesavers sitting in the box waiting to be put on. They do look better lowered.
Old Dec 21, 2004 | 03:53 PM
saalanghae's Avatar
saalanghae
Enjoy,
Could you please PM me.. I would love to use your help if I could. :o
Old Dec 21, 2004 | 03:55 PM
TruUndrtkr's Avatar
TruUndrtkr
lowering it is the thing 2 do..i need 2 lower mine a little more...
To Thninking About Lowering?
Old Dec 21, 2004 | 04:51 PM
jedicowboy's Avatar
jedicowboy
I would suggest that you put a hundred or so miles on the car before you get an alignment. Take measurements before you lower and you will notice that it will continue to get slightly lower as time passes and the more it gets driven. Also, if you don't like it after it is lowered (I doubt that will happen) you can raise it back to the exact highth it was before if you have good measurements.
Do it
Old Dec 21, 2004 | 05:17 PM
MSGvette's Avatar
MSGvette
I love the look my lowered vette. I am careful going over speed bumps and driveways. You will get used to being careful. It will become automatic for you. Just wait till your sitting next to another vette that is'nt lowered.
Old Dec 21, 2004 | 08:51 PM
BeastieBoys21's Avatar
BeastieBoys21
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
i want to lower mine, just have to figure out how low i can go
