Jammed Seatbelt
Old Dec 21, 2004 | 11:14 AM
cjlaw73's Avatar
cjlaw73
Default Jammed Seatbelt
Hey guys the seatbelt on my passanger side has jammed up on me. With a little jiggling (similar to other wrist actions...ha ha) I can get it out long enough to buckle someone in who has been getting to weight watchers regularly. When I had the car at a dealer last week they told me that there apparently was a recall on something in the seatbelt to prevent them from curling (which ironically my driver side already does). They told me that both would need to be completely replaced which after other recent work I don't even want to ask the cost. Does anyone know a temporary fix (or permanent if it exists) to alleviate the embarrassment I had last week of having to shimmy the thing to get a date buckled in? Or any similar advice to help me out?
Old Dec 21, 2004 | 11:15 AM
cjlaw73's Avatar
cjlaw73
Default By the way...
In case it matters it is a C5, '99 coupe....
Old Dec 21, 2004 | 11:17 AM
mjallen40's Avatar
mjallen40
My seat belts were repaired under a recall, it is a very quick procedure. Being a seat belt, I would not mess with any "temporary" fix. (1999 as well)
Old Dec 21, 2004 | 11:48 AM
C6 NOIR's Avatar
C6 NOIR
St. Jude Donor '03-'06-'07-'08-'09
GM dealer replaced mine on the '98 at no charge (was still under warranty)....they were reluctant till I countered them with it being a safety issue.
Old Dec 21, 2004 | 12:45 PM
Texasvet94's Avatar
Texasvet94
5th Gear
I was under the impression that the seatbelts had some type of longer warranty? Like 100k perhaps? Just what I heard I would definately ask some different dealers.
Old Dec 21, 2004 | 01:52 PM
corvetterookie's Avatar
corvetterookie
3rd Gear
Default 99 seat belt frozen
Dealer ordered part(retracgtor) for my passenger side belt. It is a belt kit 14.875 for $125. I haven't had it installed yet.
Old Dec 21, 2004 | 02:14 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Safety will get them moving.
Old Dec 21, 2004 | 04:17 PM
Vector's Avatar
Vector
My 1998 had a seat belt recall several years ago. Fixed at no charge!
Seat Belts are safety. If they don't want to fix it for free asked them to put that in writting and sign it so your next of kin knows who to sue should something happen!!!!!!!!
Good Luck!
Old Dec 21, 2004 | 04:55 PM
cjlaw73's Avatar
cjlaw73
Made an appt. for next Tuesday for the belts and to correct the new tire gauges. Guess what the gauges were apparently damdged when new tires were installed at a Firestone dealer. They told me to send them an invoice. Maybe they are going to help me out. If so, I'll give you the update on that as well.
Old Dec 21, 2004 | 05:10 PM
atl97vette's Avatar
atl97vette
From: You want HOW much for that Corvette part??? Atlanta GA
GM will fix it under a recall. My passenger side seat belt did the same thing and it was repaired under recall.
Old Dec 21, 2004 | 05:14 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have a passanger belt for sale if you want it, its black from an 00 coupe.
Old Dec 21, 2004 | 06:56 PM
cjlaw73's Avatar
cjlaw73
Screw, thanks for the offer. Let me see what happens on Tueday because my interior is black.
Old Dec 21, 2004 | 07:43 PM
Johnny Vig's Avatar
Johnny Vig
They should do it. There shouldn't be an expiration date on a recall, especially one for safety. Make sure you don't take no for an answer.
Old Dec 21, 2004 | 09:47 PM
Grand Slam's Avatar
Grand Slam
If I remember correctly, the recall work involved slipping a little piece of plastic into the retractor so the belt wouldn't curl over. Pretty trivial thing.
Old Dec 21, 2004 | 10:00 PM
SamsBud
Guest
Posts: n/a
There should NOT be a charge for a safety recall item - it is mandatory that it be fixed on GM's dime.
Old Dec 21, 2004 | 11:20 PM
HeyVern's Avatar
HeyVern
From: Grace Valley: A small, peaceful & beautiful valley in the Volunteer State
My first C5 was a 99 and took it in for the recall. The dealer did the drivers side insert but not the passenger's side...but said they did. After several years of untwisting the passenger side and blaming my wife, I took it to another dealer who confimed the part was never put in. Way out of warrenty but fixed for no cost. Should never be a cost for a recall item....
Old Dec 21, 2004 | 11:37 PM
screw991le's Avatar
screw991le
Anyone have the TSB # for this?
To Jammed Seatbelt
