Exhaust installation
http://97vette.com/howto/mufflers/index.html
From there, I unbolted the flanges in front of the rear axle, and then unbolted the hangars. Let the muffler lay down on the garage floor, and used a Lisle Exhaust Pipe Cutter to safely cut the stock system in front of the mufflers.
Each side was properly disposed of, in the trash bin, where the stock exhaust system belongs. The Bullets were in 3 pieces - over the axle, the resonator assembly, and then the tailpipe section.
I slipped the over-axle pipe in, and tightened it at the flanges. Then, just followed with the next 2 pieces. Repeated for the other side, then tightened the hangars. Then I was ready to line everything up with a level and tighten the clamp behind the rear axle. Then I lowered the car back to the ground, used the level again to line up the tailpipe/tips, and tightened the clamp on that section.
It's a breeze. If you have a floor jack, I don't know why someone would pay a shop for lift time. Then again, I'm probably younger than the average Corvette owner demographic.
