Seat removal question
Old Dec 22, 2004 | 07:00 PM
Autoworker's Avatar
Autoworker
Default Seat removal question
When you remove the power seats from the car, do you need to disconnect the battery first? No problems with disconnecting seat plugs with battery connected? Thanks.
Old Dec 22, 2004 | 07:08 PM
blazeone's Avatar
blazeone
No, I didn't and nothing blew up.
Old Dec 22, 2004 | 07:09 PM
50-50's Avatar
50-50
Removed mine to install sound deadener with radio blasting (battery connected).
Of course you probably should be careful not to pinch a wire.
Old Dec 22, 2004 | 07:11 PM
Autoworker's Avatar
Autoworker
Thanks gentlemen, just wanted to make sure before I pulled 'em out.
Old Dec 22, 2004 | 07:16 PM
Mike McCoy's Avatar
Mike McCoy
You should just for safety. If you pinch the harness or nick it with the seat, you could cause a short. With all the computer stuff in these cars you never know what might happen. It will cost you some seat and radio settings though. It seems others above didn't have any trouble. I would guess the shop manuel suggests it.
Old Dec 22, 2004 | 07:24 PM
1Patriot's Avatar
1Patriot
It is so simple to disconnect the negative terminal and avoid "Murphy".
Old Dec 22, 2004 | 08:06 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Old Dec 22, 2004 | 11:40 PM
I've taken mine out a number of times and never disconnected the battery. You should be fine.
To Seat removal question
