installing chrome exhaust plate
Old Dec 26, 2004 | 04:15 PM
bpc4me's Avatar
bpc4me
Default installing chrome exhaust plate
Hey all
Got a chrome exhaust plate for xmas and want to put it on.
Does anyone have a suggestions on cleaning and prepping the area? Or can I just wash and place on?
Old Dec 26, 2004 | 04:17 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Originally Posted by bpc4me
Hey all
Use some denatured alcohol and really thoroughly clean the area. The tricky part is to get the thing on straight and level. Take your time and if possible get it up on a lift. Once those things are on with the double-sided tape, they are REALLY hard to get back off. Good luck.
Old Dec 26, 2004 | 04:27 PM
DaBoz's Avatar
DaBoz
Use industrial type vel-cro
Old Dec 26, 2004 | 04:29 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
[QUOTE=Red_Once those things are on with the double-sided tape, they are REALLY hard to get back off. Good luck.[/QUOTE]
They look really nice to dress up the back.
Old Dec 26, 2004 | 04:34 PM
zeeman's Avatar
zeeman
Yep...denatured alcohol on the surface.....wipe dry....I placed a level on my knees,held it up against the bottom of the plate.....very lightly..and I can NOT state that enuff..very lightly place the plate against the surface you are setting it on...when you look at the level to see if it is level...Push it on firmly and you should be set.....!!
Zeeman
Old Dec 26, 2004 | 06:59 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
and watch that tape...it REALLY sticks. You basically get one shot at the placement. Do several "dry runs" before you peel the backing off the tape. You might consider some witness marks with chalk or marker to help you align everything.
Paul
Old Dec 26, 2004 | 07:17 PM
Z0SLIK's Avatar
Z0SLIK
Zeeman
Looks very nice!!
Old Dec 26, 2004 | 07:20 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
All of the above is great info. In addition I used wide masking tape at the top to assist in placing the plate. Once I got it in place I just used the masking tape like a hinge to lift it up and peel away the double sided tape. Swing it back down and it should be right in place. Worked like a champ!
Old Dec 26, 2004 | 08:12 PM
MY1STPEWTER's Avatar
MY1STPEWTER
The best part of this information is try to get it up on a lift. I wish I had done this. It will make it so much easier since it is so low to the ground.
Old Dec 26, 2004 | 08:26 PM
jrose7004's Avatar
jrose7004
Thats it!!
Old Dec 26, 2004 | 09:16 PM
91LSMAN's Avatar
91LSMAN
I installed Dad's yesterday. I eyeballed it. Looks Great.
(Hopefully new pics tomorrow-Just polished/sealed/waxed for about 7 hours)
Old Dec 26, 2004 | 09:22 PM
JHALL8569's Avatar
JHALL8569
yeah pretty much one shot and youd better make it a good one....once that plate sticks on it's on for good!!....they do make the c5 look alot better...nice mod
To installing chrome exhaust plate
