Top leaks
Old Dec 27, 2004 | 08:14 PM
Big Jay E's Avatar
Big Jay E
Default Top leaks
I have only had the top out of my 03 coupe twice.Last time was six months ago. Now it is raining, it is leaking at the front of the passanger side when it rains heavy. Is it possible to partially remove it, then reinstall it and make the leak stop.
Anyone had this happen?
Jay
Old Dec 27, 2004 | 08:56 PM
There are several things you might try. You can put some silicone grease on the weatherstripping, adjust the top to where it latches down a little tighter, or have the window adjusted to tilt in a bit more. Hopefully one of these would stop the leak.
Old Dec 27, 2004 | 10:03 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
03' its covered under warranty, take it back.
To Top leaks
