Well I finally took the time to learn how to post a pic, so here is my baby...sorry about the poor quality, ripped the cover off and took a couple quick pics, it was like -15 outside. Should I lower this thing? Because its black the gap is not as noticable.
p.s. here are 2 of my good friends....Arthur and Gus.
Nice car. I've been thinking about lowering mine as well. Any idea how much it costs?
as i understand it is free. you just have to lower it on the stock bolts. if that is not low enough, you can cut the bushings and put a longer bolt in rear. for instructions go to "other" menu and look under tech tips.
At least lower it on stock bolts if nothing else. Takes about 10 minutes and looks much better... I did mine about a month ago and it worked great using Patches' pictures. I may go lower now by cutting bushings/long bolts in rear, but I still can't decide.
Nice car. Lowering it does make the car look good, but keep in mind the area you will be driving the car in. If you have an angle to your driveway, it will scrape more and you will have to be careful of any speedbumps or rises in the road.
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
I have mine lowered on stock bolts. You'll have to drop by the firehall in the spring when we get them out again. Lowering does make a BIG difference, gets rid of the 4X4 look.
