Caliper Paint, Recommendations?
Old Dec 29, 2004 | 05:35 PM
Derf's Avatar
Derf
Default Caliper Paint, Recommendations?
Looking for a good caliper paint, brush on. What and where? Thanks
Old Dec 29, 2004 | 05:39 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Rustoleum Sunrise Red Gloss.
You can by it anywhere.
I did my calipers with it 3 years ago with a brush and they still look great.
One of the nicest mods I've done to the car and by far the least expensive.
The can of paint was $3.49 and I've done 5 or 6 cars with it and still have more than half the can.
Old Dec 29, 2004 | 05:53 PM
I used Folia Tec that I got from Xtreme Motorsports. Bought it a little over three years ago and the paint has held up extremely well. Goes on easy, dries rock hard and has a nice gloss to it.
Old Dec 29, 2004 | 05:57 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
GLENNM27,
Did you do the letters in white, or is that just the metal from the caliper cleaned up? Either way, it looks good! Zuti
Old Dec 29, 2004 | 06:00 PM
Glennm27's Avatar
Glennm27
Originally Posted by Zuti
GLENNM27,
That's just the metal. After painting, I just brushed the raised CORVETTE letters with a light (fine) sand paper. I do the letters occassionally this way.
Thanks for the compliment.
Old Dec 29, 2004 | 06:42 PM
wolfman04's Avatar
wolfman04
[QUOTE=Glennm27]Rustoleum Sunrise Red Gloss.
Man thay look what did you use to clean them before you painted them?
Old Dec 29, 2004 | 06:46 PM
RandyC5's Avatar
RandyC5
Check out this site.....their process is a bit more detailed and doesn't require your from taking your calipers off the car.....worth the look!!
http://fixedroofcoupe.com/howtodefau...ipers&pages=10
Old Dec 29, 2004 | 07:06 PM
Glennm27's Avatar
Glennm27
The car was only 2 days / 90 miles old when I did them, BUT I did clean them with soap and water and alcohol.
BTW: I did NOT take the calipers off the car, just removed the wheels.
Old Dec 29, 2004 | 07:56 PM
ALLEGRO's Avatar
ALLEGRO
Duplicolor Caliper Paint
Painted "on the car" with 2 coats, very easy and took only a couple of hours for the entire job.
Letters are in silver with a paint marker.
Old Dec 29, 2004 | 10:08 PM
KARSC5's Avatar
KARSC5
Used Rustoleum also (Spray). 4 coats then 1 coat of clear. Did mine last winter.
To Caliper Paint, Recommendations?
