50 Additional HP - What's it take?
Old Dec 30, 2004 | 01:49 PM
Great Dane's Avatar
Great Dane
Default 50 Additional HP - What's it take?
I've been trying like crazy to resist this urge but I think I'm losing the battle. So, it's time to get serious and find out what I can do and for how much to take my totally stock 04 up another 50hp. I've read individual threads about air boxes, catbacks, headers etc. but I don't think I've read a specific thread about what it would take to accomplish something like the above mentioned hp increase, and approximately how much it might cost assuming I do no work myself - mechanically challenged.
A couple of provisos, I don't want to void much warranty if I can help it, and here in Ohio we have tailpipe EPA testing so after any mod work it would still have to pass like it will now. Last, I need somebody in the Northeastern Ohio area that I can trust to do the work.
Man, I know I shouldn't start down this road, but.................
Old Dec 30, 2004 | 01:51 PM
USA-VET's Avatar
USA-VET
headers, high flow cats, intake, catback and a good tune!
approx. $2500-$3000
or just get a wicked cam
Old Dec 30, 2004 | 01:57 PM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
To get 50rwhp increase I've been lead to believe gonna have to go a little further than bolt-ons; headers, cat-back, intake & dyno tune will probably get you real close to 50 but most likely not there. I've been told heads/cam only way to get LS1 to 350rwhp. As for Northeast ohio, just ran across this place: Hutter Performance Center which was mentioned by Al from StainlessWorks (header mfg.); I have heard good things about a few other places around here, PM/e-mail me and I'll forward them on to you.
For other NorthEast ohio info, post/check in Events and Regional...Great Lakes forum.
Old Dec 30, 2004 | 01:58 PM
KamPow3r's Avatar
KamPow3r
I say:
Cold Air Intake
Exhaust
Longtubes
Good Dyno Tune
Maybe give you a few more hp with a good tune.
Old Dec 30, 2004 | 02:08 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Bolt ons will get you close but it will be tough.
Vararam - $350 (best hp gain out of intake choices)
LT headers w/ cats - $1250-1750 (price depends on what you buy. LGM's are popular but very expensive. Similar gains will be found with dynatechs, kooks, FLP's for $400 less)
Cat back exhaust - $900-1100
A good dyno tune is definitely necessary as well in order to get you the best gains. I think 50rwhp is difficult to achieve but possible. Installtion should run you another $500-600, so you are probably looking at a total cost of around $3500 including the tune.
Old Dec 30, 2004 | 02:17 PM
BlownV6's Avatar
BlownV6
Nitrous Kit
Old Dec 30, 2004 | 02:19 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
naws
Old Dec 30, 2004 | 02:49 PM
90 droptop's Avatar
90 droptop
You need two big red "R" stickers.
Old Dec 30, 2004 | 02:53 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Headers,cam and a dyno tune < 2,000dollars if you do the work yourself.
Old Dec 30, 2004 | 02:56 PM
99SilverC5Coupe's Avatar
99SilverC5Coupe
Do you a 6spd or auto? No first had experience... but if your running an auto ...I have seen quite a few posts that say rear gears and a higher stall TQ converter will give the feel of 50+ hp and you won't have to crack the motor or worry about emissions...
Old Dec 30, 2004 | 03:02 PM
Morzoff's Avatar
Morzoff
Originally Posted by StephenT
naws
I agree that is the best "BANG" for the buck
Old Dec 30, 2004 | 03:13 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Gears won't give you a single HP, but if you're looking for the performance equivalent of 50 hp they'll do AT LEAST that and more......
Preferably 4.10's in an MN6.....
$1500, installed.
Old Dec 30, 2004 | 03:15 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Spray it...
Automag928's Avatar
Automag928
All bolt ons and a good tune is going to get you close...Or do all bolt ons and a nice little cam and you are guaranteed 50rwhp.
slamar1's Avatar
slamar1
The easiest and cheapest way is NOS
Old Dec 30, 2004 | 03:33 PM
boatboatboat's Avatar
boatboatboat
$1500, installed.
I agree, who gives a rats @ss what the dyno says, HOW DOES IT DRIVE...........a gear swap will give you an instant rocket ship.
Old Dec 30, 2004 | 03:46 PM
hltambur's Avatar
hltambur
4.10 gears made a world of difference in my '02 coupe. $1500 installed with a core swap. WOOT!!!
To 50 Additional HP - What's it take?
Old Dec 30, 2004 | 03:59 PM
D.K.'s Avatar
D.K.
Only problem is w/ the auto tranny and if you do a lot of freeway driving. I'd love to put 4.10's in mine but I cruise on the freeways here in So. Cal at 75mph or so for long periods. I think I would be turning over too many rpm's and gas mileage would suffer. I wish we had a 6 speed auto!
What would be a decent ratio for auto trans that makes sense?
Old Dec 30, 2004 | 04:06 PM
Joe Diver's Avatar
Joe Diver
CF Enhanced Member
St. Jude Donor '06
If you did all the bolt on's to get close to 50....and then do the throttle body bypass to push you over...
Sorry...had to throw that in there.....
Old Dec 30, 2004 | 04:26 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
What makes more HP?? More air & gasoline!!!
Get a cam and valve springs.. then get it tuned. OR you could install NOS...
VR
