Weatherstrip Lube
Old Jan 1, 2005 | 11:42 AM
tdsteele's Avatar
tdsteele
Default Weatherstrip Lube
I bought a small tube of GM Dielectric Silicone Grease for my weatherstripping. Is there any special way or suggested tips about how it should be applied?
Thanks.
Old Jan 1, 2005 | 11:52 AM
Poptops's Avatar
Poptops
Just use it sparingly or it will leave "it's mark" on your glass, etc.
Old Jan 1, 2005 | 12:31 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Use just a tiny dab on the tip of your finger - a little goes a very long way!
The whole tube is probably enough to do every C5 here on the Forum, and still have some left over!
Old Jan 1, 2005 | 03:23 PM
atz06's Avatar
atz06
Does Pepboys or Autozone carry Dielectric Silicone Grease? Where can I get one? Thanks.
Old Jan 1, 2005 | 06:14 PM
vettenuts's Avatar
vettenuts
Got mine at NAPA. I put it on with my fingers and wipe excess with a rag.
Old Jan 1, 2005 | 07:31 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
If you can get the weatherstrip warm the grease will spread easier.
Old Jan 2, 2005 | 01:19 AM
tdsteele's Avatar
tdsteele
Thanks for all of the advice. What a great forum!
Old Jan 2, 2005 | 04:59 AM
JNS's Avatar
JNS
St. Jude Donor '06-'09
How often should the weatherstripping be lubed? My car is two yrs. old and stays in the garage except for weekends.
Thanks,
Jeff
Old Jan 2, 2005 | 03:28 PM
Use as little as possible to coat the weatherstrip, massage it in a bit, let it cure a while, then wipe it down with a clean cloth.
Old Jan 2, 2005 | 04:24 PM
Evil-Twin's Avatar
Evil-Twin
Yes they do...
I take a small dab on my finger, and massage it into the weather stripping. once I finish all the rubber, I go back and wipe it down with a clean cloth, you will never wipe it all off. This will also rub it in some more and remove any excess.
Old Jan 2, 2005 | 04:29 PM
EscapePod's Avatar
EscapePod
Originally Posted by Evil-Twin
Yes they do...
Sometimes, I leave it on overnight. I usually do it once per year ... maybe twice would be better here for the hot Florida sun, but I'm lazy.
Old Jan 2, 2005 | 06:24 PM
csexton's Avatar
csexton
Twice a year! Fall and Spring
To Weatherstrip Lube
