12 disc cd changer
Old Jan 2, 2005 | 06:13 AM
Rattler71's Avatar
Rattler71
Default 12 disc cd changer
Was the 12 disc cd changer an option on 04 Z06's?
If not, is the connector back there to hook one up? I want to use the factory disc changer and not an aftermarket one.
Scott
Old Jan 2, 2005 | 09:33 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
this has been discussed many times before.
you will need the CD Changer harness that goes from the passenger side footwell to the rear of the car.
the connectors for the changer are in the passenger side footwell, you can get the installation kit from either ken fitchner, fred beans, or your local chevy dealer.
it will have the harness, mounting brackets and instructions for installing the factory CD Changer.
try doing a search on this subject.
Old Jan 2, 2005 | 10:12 AM
Rattler71's Avatar
Rattler71
Thanks very much for the info!
Scott
Old Jan 2, 2005 | 01:22 PM
DI2FLY's Avatar
DI2FLY
One thing to keep in mind is that mine skips when I hit a bump.
It has done it since day one, and I wonder how much worse it could be with the slightly harsher ZO6 suspension.
I have a 99 Z51 coupe.
Old Jan 2, 2005 | 01:27 PM
TkitPlz's Avatar
TkitPlz
I have the 12 disc changer in my 04 Vette and it works perfectly. No skipping when hitting bumps, etc. Dan
Old Jan 2, 2005 | 01:30 PM
Boozman's Avatar
Boozman
Good thought
Old Jan 2, 2005 | 03:17 PM
Mike Mercury's Avatar
Mike Mercury
the factory changer has zero - nada - none... read-ahead-optimization buffer.
To 12 disc cd changer
