Check Engine light how to chk codes?
Old Jan 2, 2005 | 12:30 PM
Hall1836's Avatar
Hall1836
Default Check Engine light how to chk codes?
Check engine light came on today 2001 coupe, is there away to check codes using a paperclip to computer plug in like C-4s? How do I find out what this is in reference to, all gauges read okay. Thanks.
Old Jan 2, 2005 | 12:35 PM
BLAZBYU's Avatar
BLAZBYU
Start the car and hold the options button and press the fuel button four times fast. It will put the DIC in Diagnostic mode and you can read the codes and clear them as well. Codes are listed in the tech section of the forum.
Old Jan 2, 2005 | 12:49 PM
VetteSiNz's Avatar
VetteSiNz
It might be just a loose gas cap.
Here's the link for codes: http://www.stengel.net/diccodes.htm
Old Jan 2, 2005 | 01:09 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
The code or codes that set off the check engine light will have a C after it which indicates current, His for History
Old Jan 2, 2005 | 01:19 PM
Boozman's Avatar
Boozman
Thanks good info
Old Jan 2, 2005 | 02:37 PM
Hall1836's Avatar
Hall1836
Thanks for your responses will go out in the garage and try it right now.
Old Jan 2, 2005 | 02:41 PM
F.J.B.'s Avatar
F.J.B.
From: Vette Doctors Performance RX450 - 466RWHP !!!
Had the check engine light go on on my DD a few weeks ago.
Hit the onstar and like Vettesinz said...it was just a loose gas cap!
Old Jan 2, 2005 | 02:56 PM
Hall1836's Avatar
Hall1836
Just checked the codes and came up with the following 10PCM 1 code#PO128C. Checked the attached thread and that code was'nt listed, anyone have any idea what this may be before I make an appointment with the dealer? Could stabile in the gas have anything to do with this? Thanks again grreat web-site.
Old Jan 2, 2005 | 03:17 PM
Hall1836's Avatar
Hall1836
ttt
Old Jan 2, 2005 | 03:23 PM
Zilla's Avatar
Zilla
Just did a search on the forum and came about the code you indicate and it says:
PO128-ENGINE COOLANT BELOW REGULATED TEMP
Old Jan 2, 2005 | 03:50 PM
NSTG8R's Avatar
NSTG8R
P0128
"if engine coolant fails to reach a preset target temp. before a calculated air flow is accumulated DTC P0128 is set"
Conditions for setting DTC
The calibrated amount of the engine runtime as been met
The calibrated amount of engine air flow has been met
The calibrated minimum engine coolant temp. of 75C (167F) has not been met.
In other words, your coolant temp is too low.
Have you recently intsalled an aftermarket thermostat?
Old Jan 2, 2005 | 04:11 PM
Hall1836's Avatar
Hall1836
No changes other than smooth air bridge coupler thats it, previous owner did coolant by-pass for throttle body could that have done it? I have only had the car a few months no problems under 10,000 miles had it out on cooler days other than today. About three weeks ago had the car into the dealer for the column lock recall where they flashed the computer but have used the car since then with no problems. The check engine light came on after the car was up to temp and had been run about 8 miles.
Old Jan 2, 2005 | 06:42 PM
Hall1836's Avatar
Hall1836
Could this be the result of a bad temperture sensor? How would I check that an d where is it located? (Have to get service manuals for this car!).
To Check Engine light how to chk codes?
