Clear top "peeling" -- anyone else?
Old Jan 12, 2005 | 03:28 PM
nuke61's Avatar
nuke61
More information for anyone who has the peeling on the passenger side removable top.
Mike Locke has been contacted about my wife's '98 and her friends '97 "glass" top peeling issue and he is looking for more information. If you don't call in, then it becomes an "isolated" incident and nothing happens. If you call and report that you have the SAME THING happening to your car, they they might admit that at least some batches of tops had quality issues, which may lead to a replacement. Mike is apparently a national GM rep that handles complaints.
Mike Locke, 1-866-952-4368 Extension 57748
Old Jan 12, 2005 | 03:40 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Originally Posted by nuke61
So, do you all consider this a defect in materials and/or workmanship? I know that it's been a long time, and there has to be some reasonable time period on a warrantee, but it seems to happen the same way (peeling) and in the same place (passenger side) or not at all. IOW, the tops that have this problem are defective.
Am I reaching, grasping at straws, or does my argument seem reasonable?
Your argument is reasonable but expecting the General to write a check isn't. Ain't gonna happen.
Old Jan 12, 2005 | 03:58 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Add one more A buddy of mines 01 same..same spot..I do know you can have the top recleared..One question does everyone keep the top waxed??
Old Jan 13, 2005 | 06:58 AM
MDog00's Avatar
MDog00
Default Lexan Peel
The equation is quite simple really - Mega doses of solar radiation (UV) plus Lexan plastic equals the Peel [UV+LX = $1200]
Old Jan 13, 2005 | 09:50 AM
BigJoe's Avatar
BigJoe
I Zaino mine every time I do the rest of the car. So far no problems, but it has been on only 2-3 months, so its to soon to tell.
Old Jan 13, 2005 | 09:52 AM
C6 NOIR's Avatar
C6 NOIR
St. Jude Donor '03-'06-'07-'08-'09
MyVetteDream, apparently it might not happen to your car. I had never seen the question asked before, but the feedback that if it does happen, it only affects the passenger side with about a 4" wide strip is strange.
there was a thread more than 6 months ago addressing this issue....namely, the 4" wide strip on the passenger side...on my '98 this occurred after approx. 3 years....the top for my '03 is still in mint condition in it's original bubble wrap
Old Jan 13, 2005 | 10:11 AM
Lowcash's Avatar
Lowcash
Mine is doing the same on the pass side. I heard it can be replaced under warranty. I haven't had a chance to call and find out if its true.
Old Jan 13, 2005 | 11:55 AM
saber's Avatar
saber
I took a buffer w1000 grit then 2000 grit and took the coating off on my 97. It has a few swirls but does'nt look too bad.
Old Jan 13, 2005 | 12:08 PM
DoomDRV's Avatar
DoomDRV
This is a facinating thread! I have an 01 coupe and my glass top is fine, however, we have had an unusually cold summer so I had my matching (silver) top on for the majority of the time. I noticed in the fall that I was developing a reflection in the paint about three inches from the front that stretched from drivers side to paasengers side and was aout four inches in the middle and tapering down to nothing at the outside. It looked almost like a stretch mark as if the metal was under pressure but it is there if you look carefully while on the car or not. Defect?? Any other experience like this?
Old Jan 13, 2005 | 02:50 PM
Tom/99's Avatar
Tom/99
The clear top from my 99 still looks like new. I have kept mine waxed, has your top been waxed? If not, that may be the reason the clear coat is peeling. I never had any problems with the top on my 90 either.
Old Jan 13, 2005 | 03:58 PM
xlr8shn's Avatar
xlr8shn
Clear top on my 99 has the problem also... 4-5" strip on pass side running front to back...
Old Jan 13, 2005 | 04:04 PM
xlr8shn's Avatar
xlr8shn
I left a message with Mike. Left my name, phone #, VIN and breif desc of the clear top peeling/separating.... Do it in case the bean counters there care...
Old Jan 13, 2005 | 04:07 PM
94AdmiralCoupe's Avatar
94AdmiralCoupe
What about putting window tint over it before it starts peeling. Would that help?
Old Jan 13, 2005 | 06:45 PM
nuke61's Avatar
nuke61
I have no idea what helps, if anything, and I don't know if calling and reporting the same condition will get anything done. What I do know is our call resulted in the local dealer being called by the national office and arrangements being made to take in our car to look at it. However, they did NOT tell us that it will be covered -- just looked at and documented.
Old Jan 13, 2005 | 06:49 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
My 2000's top does the same.
Everyone I know with this problem has it happen on the passenger side. It appears to be some form of common manufacturing defect.
Old Jan 13, 2005 | 06:53 PM
pops98's Avatar
pops98
Mine is doing the same thing. Not to bad now but I expect it to get worse.
Old Jan 13, 2005 | 06:59 PM
Daytona2000C5's Avatar
Daytona2000C5
My 2000 Coupe (Tinted tops) did the same thing. I traded it for a convertible.
To Clear top "peeling" -- anyone else?
Old Jan 13, 2005 | 08:36 PM
silverminevette's Avatar
silverminevette
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '03-'04-'05-'06
Yep - 98 - same problem.
Old Jan 13, 2005 | 08:43 PM
Dave1998's Avatar
Dave1998
I bought an 03 top for my 98. I am curious what wax to apply ?
Will Maquires NXT work ?
Dave
Old Jan 13, 2005 | 09:17 PM
GTSLN97's Avatar
GTSLN97
Originally Posted by jrose7004
That is the nature of the beast! Mine got so bad that I painted it body color!
I did the same
