Problem- engine heat or something else?
Old Jan 6, 2005 | 03:12 PM
VA CORVETTE 757's Avatar
VA CORVETTE 757
Default Problem- engine heat or something else?
Does anyone else find that when they are driving with the windows up with no heat or AC on that it gets pretty hot inside the car? I hope that is the engine heat or the sun blazing through the glass top. Anyone?
Old Jan 6, 2005 | 03:21 PM
chaase's Avatar
chaase
St. Jude Donor '12
I have had that problem in the summer with the top down. It is the engine heat. You will see people doing the Frost King Mod, to quite down the interior and to insulate the cabin from the heat.
Chris
Old Jan 6, 2005 | 04:06 PM
jman1's Avatar
jman1
yeah.. it's almost unbearable to drive in traffic in the summer
Old Jan 6, 2005 | 04:10 PM
atl97vette's Avatar
atl97vette
From: You want HOW much for that Corvette part??? Atlanta GA
it gets pretty balmy sitting in traffic without a/c but that comes with having a V8.
Old Jan 6, 2005 | 04:18 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Tunnel heat, very common problem. Plus with no air on, your own 98 degree body heat heats up the car also, but I would mostly say the tunnel gives off the most heat.
Old Jan 6, 2005 | 05:01 PM
OC1Dave's Avatar
OC1Dave
It's the"glass" top. Use the solid top in the summer and the clear one in cooler weather.
Old Jan 6, 2005 | 05:36 PM
Corvettes have historically put a lot of heat inside the cabin. Try driving one of the C3's.
To Problem- engine heat or something else?
