Tire question
1) I've been driving for 31 years and have had one blowout in all those years. All of the other (3) tire issues have been nails that caused either very slow or no leaks, so getting to a tire shop was painless.
2) Have you ever noticed that rounding a bumpy or pot-holed corner results in some very disconcerting side-stepping? That's due to the sidewall stiffness of the runflats. Yes, other manufacturers softened their sidewalls for a slightly better ride, but with a resulting shorter runflat distance. However, runflats are always more expensive and heavier than their non-runflat brethren. Keep in mind that the extra 6+ lbs that a runflat tire carries is rotating, unsprung weight which harshens your ride considerably.
3) Goodyear does make one of the best all-around set of tires in the world for a C5. They are called GSD3s and not only provide a superior ride, but also are exceptional in wet weather. The added two bonuses are that they are less expensive than almost all the major runflat and non-runflat tires and they are made right here in the USA.
Highly recommended
Highly recommended
Well put Dave!! I also went with the D3's and love them. I had a flat in the old runflats and nobody wanted or could work on them. The tire places have to be certified to work on runflats. Also they have to have a cage built to inflate the tires in. So I bought a plug kit and repaired the tire myself. So now that I have a plug kit and a compressor there's no reason to have the runflats. And the difference in the ride and noise is astonishing. Get yourself some D3's and don't look back.
