burnout
Old Jan 10, 2005 | 09:55 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Originally Posted by boarddirector
MN6 here. Only problem is not doing a burnout.
I feel your pain!
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
Have fun, but play safe
Old Jan 10, 2005 | 09:57 PM
C5 RACNG's Avatar
C5 RACNG
Originally Posted by Pug
WOW.......
If you can't afford tires then you can't afford a Vette..........
Play if you want......
If I want to toast a set of tires every day I will.... (But I can afford to do it....)
nice avatar
Old Jan 10, 2005 | 10:43 PM
2 QWIIK's Avatar
2 QWIIK
so regardless of whether you have a stick or an auto transmission, the bad effects on the tires and car would be the same when you burn out?
Old Jan 10, 2005 | 10:45 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Originally Posted by mrgil
Back in the olden days of Ford 390's and Dodge 383's and chevy 409's we used to take dads' car out an try backing up at 15-20 mph then dropping the A3 into L now that was smokin' tires.
Old Jan 10, 2005 | 10:49 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Originally Posted by stuart
...Welcome...
the breaking method is necessary for some...
...for others there is no way to avoid breaking loose
I don't understand.
Old Jan 10, 2005 | 10:58 PM
tommyn's Avatar
tommyn
St. Jude Donor '06
My new snow tires:
TommyN
Old Jan 11, 2005 | 01:30 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
A4 burnout, but it can get expensive!
Old Jan 11, 2005 | 01:43 AM
NSTG8R's Avatar
NSTG8R
Originally Posted by 2 QWIIK
Hi, Im obviosuly a newb.
I have a quick question, I love corvettes, but I never knew if automatic cars like the C6 or C5 corvettes can burn out? Can they? If so, how?
I mean, when your sitting still in your car, without the car moving an inch and all that white smoke comes up, is that possible on automatic transmission?
we have a simple solution for that .. it's called a manual
Old Jan 11, 2005 | 01:50 AM
NSTG8R's Avatar
NSTG8R
weird .. my dad's old 396 (w/ 3 on the tree) when placed in 1st, once you hammered it the car wouldn't budge ... it would stay in one place all day long.
hurray for the '67 Chevelle SS 396 (w/ (shaved?) heads, 750cfm carb, P&P, huge **** tires and loads of other nicknacks) ... *sigh* ahh the good ole' days.
Old Jan 11, 2005 | 01:55 AM
Vette 4 Fun's Avatar
Vette 4 Fun
Originally Posted by Benpup
99 Coupe A4 here. No problem doing a burnout in fact I have to be careful not to.
2001 Vert, A4 same here take off traction control and I will burn without trying
Old Jan 11, 2005 | 02:20 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I like the information on upgrading the gearing in the A4 to get more break loose power, but I don't want to burn out everytime I take off, I want to plant and roll. I think that I will end up doing a DIFF replacement, but I am not sure what gear to do...3:15 in currently, where to go...that is another post.
Micah
Oh, I power brake mine and leave the rubber.
Old Jan 11, 2005 | 02:50 AM
  #33
ditty22's Avatar
ditty22
yep
Old Jan 11, 2005 | 06:20 AM
  #34
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Micah
I'm going for 3.73:1, hardened shafts and a mild stall (2400 lockup).
If could do all my mods all over again, I would have done gears and stall first, then blower, shift kit et al after.
EG
