Constructing a Garage Pit - Need Ideas
Old Jan 12, 2005 | 12:20 AM
Oregon1998C5's Avatar
Oregon1998C5
Default Constructing a Garage Pit - Need Ideas
I want to cut the concrete in my garage and dig a pit deep enough to stand in. I plan to pour concrete walls and floor. I have used a "drive on" pit before and it was awesome. My house is new and I have normal standard footings around all of the walls, so I am not worried about foundation/wall problems. I plan to rent a concrete cutter to cut the outline, then dig the hole, build forms, and pour the concrete. I plan to park my car over the pit, so I am not worried about buying/building a grate. Suggestions and guideance are greatly appreciated! A link to web articles would be great, but I searched and couldn't find anything good. Since I have never seen this done inside a normal house garage before, I need some good ideas...
Old Jan 12, 2005 | 12:25 AM
quick99ls1's Avatar
quick99ls1
i have never seen it but sure would love to see yours once you are done. if i can find some info i will post. good luck
Old Jan 12, 2005 | 12:35 AM
2KFRC5's Avatar
2KFRC5
I remember reading something about this before. It's been a while, but check your local building codes, if you haven't yet. Some of the requirements can be costly, if my memory seves me correctly.
Always having an exit, and proper ventilation would be my biggest concerns.
Good luck.
Old Jan 12, 2005 | 12:53 AM
GrayC5's Avatar
GrayC5
Sounds like a great idea. However, this topic may be better served over in the Off Topic section of the Forum rather than here in C5 General. At least, there you might get some different ideas from folks in the other sections of the Forum that seldom make it here to C5 General. Good luck!
Old Jan 12, 2005 | 12:55 AM
Oregon1998C5
Good Point Gray... I spend my time in C5 world and didn't notice the "Off Topic" forum. I will post it there too.
Old Jan 12, 2005 | 06:28 AM
Good luck with your project. Would be nice to have a pit in the garage.
Old Jan 12, 2005 | 07:54 AM
Flintstone's Avatar
Flintstone
Check local building codes.
Gas vapors are heavier than air, and could accumulate in the pit. It would also probably need to be covered so that no one could fall in.
At a minimum, you would want to have a venting system.
Sounds like a cool project though...
F
Old Jan 12, 2005 | 08:08 AM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
When I was growing up as a kid...they were popular...I seem to remember they got outlawed or something because they were death traps if a fire started.
Old Jan 12, 2005 | 09:59 AM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I have a pit in my garage. My main garage is built on the edge of a hill. It has a framed extension that hangs over the back slope. The floor on the extension has doubled 2X12s and 3/4" plywood flooring. I framed a hole that is about 3.5' by 7' long in the flooring. Below that I dug a hole and built walls and a floor around the hole. I have a rear "escape hatch" on it's back wall. It's mainly there in case I need to pull a tranny out. I agree with some of the warnings mentioned on earlier posts, but must add that a car on jacks and jackstands carries it's own dangers. Obviously, I never have anyone drive over the pit while I'm in it. There is always a way to walk back out. I can't imagine a more safe way to change the oil, headers, or cat back on a C5. Keep us posted on your progress.
Old Jan 12, 2005 | 10:04 AM
beckel's Avatar
beckel
I am an Architect in New York/New Jersey, so I'll chime in with some ideas and suggestions.
1. Obviously, check local reg's. If the pit is permitted, then I would suggest checking with OSHA for safety information regarding concealed spaces. The website is www.osha.gov. The book is available from your local federal government bookstore. It is the CFR volume 29.
2. Next you would probably need to obtain a permit from your local building department. This would probably require an Architect or Engineer to prepare a design for the pit.
3. Since the pit would probably be deeper than the local water table and/or frost zone, you would need to relieve the hydrostatic pressure on the sides of the pit walls. I would recommend a french drain at the perimeter of the pit to connect with the existing foundaton drainage system.
4. I would also install a sump pump and a backflow preventer.
5. Local codes may require an oil separator.
Hope this was helpful. As you can see, this little project could become a real pain.
Old Jan 12, 2005 | 10:06 AM
dvarapala's Avatar
dvarapala
Making CFOT Great Again
Many newer houses are built on post-tension slabs. You're in for a rude surprise if you try to cut through it...
Old Jan 12, 2005 | 10:20 AM
hear1's Avatar
hear1
Think about a lift as an alternate, IF you have the height. You can move it, push it out outside on casters and take it with you if you sell your house. No climbing in and out of a pit, everything at ground level etc. etc.
Old Jan 12, 2005 | 11:51 AM
WDEagle's Avatar
WDEagle
I do not think OSHA would be a concern unless this will be a place of work.
WDEagle
Old Jan 12, 2005 | 02:13 PM
paceace's Avatar
paceace
I am in the process of building a new house, and am putting a pit in one of the garage bays. The required drawings, calculations, etc are incredible. The building code is very specific (as listed above) and all listed is true: sump pump, separate emergency exit, safety cover, ventilation, increased side wall concrete thickness and rebar.
That being said, it is still an easy thing to do as this is new construction. As far as adding it to your existing house, be sure to get an expert opinion as to cutting such a large hole in the garage floor. It would be sad to see pictures of you and your car stuck down in that hole.
Great idea though, I hope you do it!!!!
Old Jan 12, 2005 | 03:16 PM
Blue Seducer's Avatar
Blue Seducer
Old Jan 12, 2005 | 03:35 PM
BlueDragon's Avatar
BlueDragon
Originally Posted by Blue Seducer
More true for us here in Cali. Going with a 4 poster here!
Old Jan 12, 2005 | 04:52 PM
JoesC5's Avatar
JoesC5
I would rank a 4-post lift as more desirabe then a pit. Even if you have a low ceiling height, you can raise the ceiling as long as there is atic space above. even if you don't plan to use the lift as a car storage unit it can be used to store riding mowers, etc during the winter. I have two of the Autolifters M6 lifts that I store my '56 and '64's on and also for wrench turning.
To Constructing a Garage Pit - Need Ideas
Old Jan 12, 2005 | 05:45 PM
raidersfan's Avatar
raidersfan
From: Spread The Virus!!!!!!! Opie and Anthony XM Satellite Radio
WDEagle
OSHA has no say in the matter. I do believe it is a residence that he plans on doing this project on, not a commercial dweling with employees.
Go for it! sound like a cool idea. Permits?? what permits, it was always here.
Old Jan 12, 2005 | 05:48 PM
madeouttaglass
Senior Member
Cruise-In V Veteran
That's my story and I'm stickin' to it.
Old Jan 12, 2005 | 10:15 PM
2K2 C5's Avatar
2K2 C5
Default storm shelter
I don't know about availability on the coast but here in the heart of tornado country, you can get installed an under floor storm shelter, steel walls, floor and sliding lid. It's strong enough to park a car on if you miss and the door is on rollers which easily slides back to enter by the ladder on the end. Leaving the door open lets you have access to the bottom of the car. It fits fairly flush to the floor so there's very little trip hazard when the car is out. Installed here around $2700. Almost forgot-solid lid means no fumes inside and fewer spiders etc.
