Reduce power ( Please Help)
Old Jan 15, 2005 | 10:58 PM
98corvette82's Avatar
98corvette82
Default Reduce power ( Please Help)
I just did the recall with my vette on Friday. So today I decide to take my car out and about 3 blocks down from my house "REDUCE POWER" AND CHECK ENGINE lights come on and my car dies on me I was WTF happend? What could this be? Maybe something to do with the Recall?
Old Jan 15, 2005 | 11:08 PM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
If you're talking about the column lock recall it is quite possible that this behaviour is a direct result of having it done.
Old Jan 15, 2005 | 11:15 PM
silverhead's Avatar
silverhead
Had my column lock recall done six month's ago (1997 A4) and this never happend to mine!
Old Jan 15, 2005 | 11:20 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please check for any codes in the DIC and post the results. After you write down the codes, errase what is storred in memory. I had a 98 and it was doing the samething. My problems were caused by a BAD Throttle Actuation Control module (TAC) and dirty chassis grounds.
Lets check and anylize the codes first. The next time this happens, pull up the codes on the DIC and reset any PCM codes that pop up. I found out that if I cleared the PCM code, the car would run correctly again. That is a SURE sign that the TAC module is at fault.
Here is how to check the codes:
http://www.stengel.net/diccodes.htm
Let me know if I can help. I have a forum post on chassis ground cleaning, take a look and maybe you can check yours out.
http://forums.corvetteforum.com/show...al+information
Dirty Chassis Grounds are starting to show up more and more, especially on cars that are drivers!
Bill Curlee
NSTG8R's Avatar
NSTG8R
time to go back to the dealership .. this is a limp mode that the car goes into whenever something bad happens. I believe an overheat (off the top of my head) causes this also .. could be nothing, could be something .. eitherway i'd blaim it on the dealer.
Old Jan 15, 2005 | 11:22 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
How old is your battery?
Old Jan 15, 2005 | 11:34 PM
98corvette82
Ok I checked the codes And this is what i got B0361 and My batt. is fairly old
Old Jan 16, 2005 | 12:40 AM
98corvette82
Old Jan 16, 2005 | 12:47 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That code is a HVAC System, Left Actuator Feedback Short to ground.
Shorts in a C5 electrical system can cause all sorts of crazy problems!
Something else to check! Take a look in your drivers foot well, behind the toe board. See if that area is wet or damp. Feel the carpet and the jute underlayment and see if it is damp! If the BCM get wet, It can also cause the car to FREAK out!!!
BC
Old Jan 16, 2005 | 04:18 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
That happened to me when my battery was very weak!!
Old Jan 16, 2005 | 04:27 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Keep us posted. This type of happening is good once the resoultion is found.
To Reduce power ( Please Help)
