Traction Control
Old Jan 16, 2005 | 09:06 AM
Too Slow '90's Avatar
Too Slow '90
Default Traction Control
When I pull out of an intersection to the left or right (90 degrees) I feel a slip in the rear. It feels almost like the tires are breaking loose but they are not. Is this the traction control at work? Thanks.
Old Jan 16, 2005 | 09:24 AM
BT-01-vette's Avatar
BT-01-vette
There is some breaking loose before the TC or AH kicks in that is what activates the system so this might be happening.
Old Jan 16, 2005 | 10:04 AM
DeeGee's Avatar
DeeGee
No it's the right foot at work!!!!!!!!
Old Jan 16, 2005 | 12:42 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
It's the limited slip differential. One wheel is turning faster than the other when turning. If you go slow the diff will slip and you won't feel anything but if you gun it they won't slip and that's what your experiencing.
Old Jan 16, 2005 | 12:45 PM
Poptops's Avatar
Poptops
DeeGee: You're a hoot! Now that's what I call a root cause analysis!
Old Jan 16, 2005 | 01:44 PM
MalaysianMenace's Avatar
MalaysianMenace
The limited slip rear differential maybe? If it was the traction control you would see "traction control active" on the DIC.
Old Jan 16, 2005 | 02:23 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The weird thing is with the tires today - you don't get much squeal out of them - which might be a good thing....attracts less LEO attention!
To Traction Control
