Headlights dim...
Old Jan 16, 2005 | 11:28 PM
GatoChulo's Avatar
GatoChulo
3rd Gear
Default Headlights dim...
I've seen this question posted before, but didn't see any replies. I'll try my luck. Does anyone else's C5's headlights dim when any other accessories are used?? Ours dim when you 1.) put windows up or down, 2.) apply brakes to stop, 3.) adjust driver seat with power options.
Dealership says it's caused by "the load of all of the electronic equipment on the alternator system." I personally think they never had seen it!
PS. Any ideas on squeal? Start machine, any temp, any warm-up time, when initially placed in drive, engine comes down & squeals. Most noticeable in tight turn areas (parking garages, quite embarrassing!). At 11,000 miles, this machine should not do this.
Old Jan 17, 2005 | 12:53 AM
98NassauBluC5's Avatar
98NassauBluC5
From: I'm a Texan, but I traded the horse for the Vette.
Well my '98 has a 527 watt amp with two 10's and everytime it hits, total "dimage" on the entire car. I think another alteranator or something might fix it. As for all other electrical things like the windows, same here. The car is a big electrical box.... I guess we need to just go with it, bro.
Old Jan 17, 2005 | 01:39 AM
red97vette's Avatar
red97vette
ive noticed some dimming of my headlights randomly. I think its when the brake lights come on too. I guess too much load on the alternator or something...i donno. Im adding an amp and sub, so i think i might add a capacitor.
red
Old Jan 17, 2005 | 03:01 AM
Rickk's Avatar
Rickk
I don't have this problem...Seems to me,,,if your headlights dim when an extra electrical load is applied, you either have an electrical problem, or your battery is weak..... Just my opinion.....
Old Jan 17, 2005 | 03:38 AM
quick99ls1's Avatar
quick99ls1
mine does it too
Old Jan 17, 2005 | 07:47 AM
JTAllen79's Avatar
JTAllen79
When I first got my 01' I had a very similar problem.My headlights would "blink" every time I applied the brakes.I also had erratic readings on voltage at the DIC but steady readings at the volt meter. Turned out to be both +/- battery connections were LOOSE by 3/4 of a turn. It was a new battery that had been replaced under warrenty at a Chevy dealer. As for the "squeel" I think you have an alternator bearing going south.
Old Jan 17, 2005 | 07:53 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Now there's a dealer with a senior tech....can't manage battery terminals????
Old Jan 17, 2005 | 07:58 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
check the tensioner..Mine was making the squeel noise and was bad. My lights dim every mornig at almost the same spot on the interstate . Going up a hill, 5 minutes after leaving home.
Old Jan 17, 2005 | 08:03 AM
JTAllen79's Avatar
JTAllen79
Exactly my point!
Old Jan 17, 2005 | 08:41 AM
gunnygotavet's Avatar
gunnygotavet
I posted this awhile ago and it seems its a common problem, mine dim when I hit the brakes.
Old Jan 17, 2005 | 08:55 AM
Oldvetter's Avatar
Oldvetter
My headlights and dashlights used to dim, my battery terminals were loose.
Old Jan 17, 2005 | 08:57 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
Mine dim from time to time.
Old Jan 17, 2005 | 09:16 AM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Mine dim when I hit the brakes, but dim more if I close both windows at the same time. Common problem with most cars. Problem would be if they dim with no input from another electrical device. It is not that the generator can't handle the extra load, it is just a momentary problem caused by the regulator catching up to the sudden drop in current.
Edited to add information from three auto electrical engineers who gave me a fairly intelligent reply as to why, this happens on modern vehicles.
Under most circumstances, if the lights dim, then immediately brighten back up to normal when closing the window, or applying brakes, it is due to the regulator and not the generator. The regulator is designed not to switch to higher output too fast, or the engine could be overloaded. Therefore, there is a a momentary drop in the output with a large load, but the PCM will signal the regulator to ramp up the generator to supply more current for the extra load.
While driving and keeping the RPMs above 1000, the generator is supplying about 35 to 40 percent of its rated output. However, while driving the regulator can and will ramp up current from the generator almost instantaneously. At idle, RPMs below 1000, if the generator is signaled to ramp up current too fast, the engine will dog down (technical term for die).
A power window will draw almost 15 amps, while a rear defogger can pull almost 25 amps, same with the air pump. Headlamps and blower motor will draw 20 amps, while brake lights will vary depending upon their wattage ratings and the number of bulbs in the vehicle.
If a car has been sitting for a while and the battery is not fully charged, the dimming will be more noticeable.
Normal as long as the light flickers when a large load is suddenly applied such as windows, lights, etc. Not normal if they flicker while driving and no extra loads are suddenly applied, or small loads such as a radio are applied.
Old Jan 17, 2005 | 09:30 AM
VetteramI's Avatar
VetteramI
St. Jude Donor '05-'06-'07-'10
My 01 did it too. Worried about it right after I got it in 03. Had to change the battery this summer and the problem went away.
Old Jan 17, 2005 | 09:43 AM
Frizzle86's Avatar
Frizzle86
well, for those looking for an improvement in their alternator. You could check out a company called Stinger. They take your factory alternator and make 100x better, used by a lot of ppl with systems.
Old Jan 17, 2005 | 10:05 AM
My headlights will dim on occasion when I use the window or seat controls. I think a lot has to do with how many other accessories are being used at the same time.
Old Jan 17, 2005 | 10:16 AM
Sportsdude's Avatar
Sportsdude
I replaced my battery and now, no sign of dimming any more
To Headlights dim...
Old Jan 17, 2005 | 10:42 AM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
I upgraded to a 175 amp alternator and a Optima yellow top in my Pace Car, and it went away!
Old Feb 1, 2005 | 02:39 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi GatoChulo -
Both of my C5's have the electronic "impulse" disease.
When the ac compressor kicks on, light mometarily dim, windows operating = dimmer lights etc.
I have noticed the electric windows causing this on other cars than just vettes.
I have not had any issues with this, just something I noticed.
The only squealing I hear in my Z comes from the passenger seat...
best regards -
mqqn
Old Feb 1, 2005 | 03:07 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Mine dim from time to time and have since I bought the car new with 3 miles on it.
