Alternative lift pads ?
Old Jan 17, 2005 | 08:27 PM
Tim04C5's Avatar
Tim04C5
Default Alternative lift pads ?
I just received my set of GHL Bullets and plan on installing them. I've been researching here how to do it. I bought a 3 1/2 ton floor jack and jack stands at Sears (on sale for $75).
Is it OK to use a 2 X 4 with an eyebolt screwed in for a lift pad, instead of the hockey pucks? Or how about a 1" piece of aluminum. As long as it fits between the body panels underneath, I can't see why that wouldn't suffice. Just looking for an easier option cause I don't have any pucks, but obviously don't want to do something unsafe.
What do you think?
Thanks...
Old Jan 17, 2005 | 08:32 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I was thinking the same...only the 2x4 would leave less clearance for the jack, 1" alum should be fine imo
Old Jan 17, 2005 | 08:33 PM
Ginzo's Avatar
Ginzo
Sure you can, just as you said as long as it fits in between the body panels. Guys use hockey pucks too!
Old Jan 17, 2005 | 08:35 PM
SlideRulz's Avatar
SlideRulz
I use these...
http://www.eliteengineeringusa.com/jacking-pads.html
Old Jan 17, 2005 | 09:26 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
How do you guys use these pads? Even with my really lower alum. jack, I couldn't possibly squeeze those pads between the car and jack.
Do they make thinner ones? How thick are these actually?
Thanks,
Mark
Old Jan 17, 2005 | 09:32 PM
T's's Avatar
T's
Cruise-In VII Veteran
I use a 1 x 2 board cut to fit, no eye bolt.
I have the same jack & stands from Sears, they work great!
Take your time & you will do fine.
T
Old Jan 17, 2005 | 09:45 PM
Tim04C5's Avatar
Tim04C5
Thanks,
Mark
I plan on using it between the jackstand and under the car, at the hoist points. I'll use the jack to lift the azz end first...
Old Jan 17, 2005 | 10:09 PM
mjmc1273's Avatar
mjmc1273
Originally Posted by SlideRulz
This is a great product for the money and a good/safe way to go.
Old Jan 17, 2005 | 11:27 PM
91C4L98's Avatar
91C4L98
I have the Elite Engineering pads and you can't beat their price of 4 shipped for $39.99!
Dave
Old Jan 17, 2005 | 11:40 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
Dave
I've got to get some of those. Helluva price for a fine product. This is one of the few products that doesn't come with the Vette tax.
Old Jan 17, 2005 | 11:46 PM
mhaber's Avatar
mhaber
The best and cheapest lift pads for C5 are the ones for BMW. They fit perfectly, cost me $6.50 a pad at my local BMW dealer. They are low profile and can be left on full time without being seen from the side of the car. Don't waste your money on $60-80 set of pucks for the C5
BMW parts dept part#51-71-1-960-752
Old Jan 18, 2005 | 12:48 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Thanks for the part number. That's great.
Old Jan 18, 2005 | 02:17 AM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Thanks,
Mark
first drive up on some 2x10`s about 2 feet long.
Old Jan 18, 2005 | 03:59 AM
NSTG8R's Avatar
NSTG8R
my dealership uses a 1x1 block of wood .. that is until i informed them of the hockey pucks .. the SM thought it was a great idea.
Old Jan 18, 2005 | 04:03 AM
RFJohnston's Avatar
RFJohnston
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
I use the ones for a BMW... They are about 10 bucks apiece and stay on the car.
Old Jan 18, 2005 | 04:04 AM
FiberglassFan's Avatar
FiberglassFan
These are not overpriced and work very well. I use a floor jack with a wood pad to lift the center of the car and place the stands under the Elite pads on the side frames. After that I pull out the jack and can gaze at all the stuff I want to upgrade.....visualizing the future LG or Kooks long tubes, Hi-flow cats, B&B Bullets, Hotchkiss sway bars, Elite chassis closure plate,....... Hey, my Bilsteins are here and I'm gonna get them in soon! Still visualizing the rest.... CarCrazy girl I am.
Jennifer.
Old Jan 18, 2005 | 08:24 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I use 4 ramps all the time so clearance is never a problem. I drive up on the front 2 ramps and then lift the back onto the back ramps. If I need extra height to remove a tire it is now easy to get the low profile jack underneath the car using a piece of wood between the jack and the car.
I also feel this is safe because the ramps are supporting all the weight - though I still use floor jacks because I don't trust anything so having the hockey pucks are still needed....
To Alternative lift pads ?
Old Jan 18, 2005 | 11:02 AM
Wicked Weasel
Is this what yours looks like?
Old Jan 18, 2005 | 11:09 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Thanks,
Mark
Sounds like you need a "racing jack" that will lower futher. Mine fits with no problem at all.
Old Jan 18, 2005 | 11:17 AM
HummelS's Avatar
HummelS
In a pinch, just about anything that won't scratch the finish will work fine - I've even used a piece of folded cardboard box with no ill effects. All you're trying to accomplish is to prevent direct contact of the jack with the rocker panel.
