Koolflex hose
Old Jan 17, 2005 | 11:01 PM
doug doo wop's Avatar
doug doo wop
Default Koolflex hose
Hi, just want to ask this question again. Does anyone have the radiator hose(upper) from Koolflex and have you had any problems with it slipping off? Are there any nice chrome hose covers out there? Thanks Doug
Old Jan 18, 2005 | 06:11 AM
wrustywrench's Avatar
wrustywrench
I have hose like cool flex on my street rod, its stainless, not chromed . Been ok. However, I like the look of the silicone hoses offered by LPE . Cool flex must be installed corectly, never get antifreeze on the rubbers,I have seen lotsof it blow off. Plus, the guys that sell it (ingleses) are jerks (to most folks)....Coolflex is just chromed flex large stream and gas line adopted from industry to autos.
Old Jan 18, 2005 | 07:11 AM
Get ahold of TRAYC6 - she ran some of this on her Z06. Looked good, but don't know what trouble if any she had with it.
Old Jan 18, 2005 | 09:12 AM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
No problems at all if installed correctly.
When I first put this on I had a problem . The rubber hose you use as a spacer comes from Koolflex with a coating on it.....it is very important that this cating is cleaned off to stop it from slipping.
I used brake cleaner and have not had a problem since
They have chrome , stainless and satin finish.....get what you think looks best
Old Jan 18, 2005 | 08:39 PM
doug doo wop
Thanks for the info Iceburgh; that maybe the problem I had. It slipped off on my way to Ocean City last Oct.I might have mentioned this down there to you.
and for Wrustywrench, who is LPE? On the internet? Thanks Doug
Old Jan 18, 2005 | 08:48 PM
iceburgh's Avatar
iceburgh
yea I think you did.....clean it real good with something that will break down the coating they put on it.... like I said I used brake cleaner.
Also note thet the neck off the Rad. is sloped down so your hose will have to be bent that way and then slowly bend it back up to where you want it
Old Jan 18, 2005 | 10:04 PM
Mike Mercury's Avatar
Mike Mercury
the keys are cleaning (like stated above) and pre-shaping to all three axis:
don't let the smaller OD of the Coolflex worry you. The I.D. is the same as the radiator and block neck I.D.'s
here are all of my Coolflex pics:
http://home.woh.rr.com/mikemercury/coolflex/c-flex0.jpg
then replace the "0" with "1", then "2", through 7
To Koolflex hose
