Black Box Evidence Used
Old Jan 18, 2005 | 02:17 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Originally Posted by ROMA 75
Controversal question....:
Is there any way that we can take off the black box from the car???
Has been asked a hundred times, at least, and the answer is yes; however, you will no longer have air bags, since the SDM is used to deploy the air bags in the vehicle. (Also pre-tensioners on seat belts in some other vehicles that have pre-tensioner belts.)
Old Jan 18, 2005 | 02:27 PM
ROMA 75's Avatar
ROMA 75
Thanks Doug for the answeer.....so there are no By pass of any sort that will be able to disconnect just the Black box,and anything else...?
Old Jan 18, 2005 | 03:40 PM
jrose7004's Avatar
jrose7004
Sounds like an example of too much car for too young drivers!
Old Jan 18, 2005 | 04:01 PM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
I work for the Police Dept. in that county. First, Muttontown is one of the top 30 richest towns in america, so the 16 yr old with a new vette is probably a learner car on his way to a Porshe or other $$$$ car. Second, Nassau county is one county you DONT want to get caught racing in, One of the Det. in the homicide squad is the pinnacle of accident recreations, and investigations. He has set the standard for the rest of the country to follow. The accidents ive seen where you would think are just accidents, he has reconstructed and has won variuos indictments on these. If you are ever in this county, be careful. By the way these kids deserve what ever happens to them
Old Jan 18, 2005 | 04:09 PM
dbirdhouse1's Avatar
dbirdhouse1
Nope, moral is how far is the government/law enforcement allowed to go...does it include self-incrimination?
Old Jan 18, 2005 | 04:11 PM
jo8243's Avatar
jo8243
Originally Posted by JTS97Z28
I dont know if this was just a coincidence or the way it was actually designed, but my friend wrecked his highly modified 98 Mustang GT. The speedometer froze at the speed that the impact occured at. The impact happened at about 80mph AFTER about 130ft of braking Just to give you an idea of how fast he was going before he started braking.
Was anyone hurt?
Old Jan 18, 2005 | 04:16 PM
F.J.B.'s Avatar
F.J.B.
From: Vette Doctors Performance RX450 - 466RWHP !!!
The only thing I saw wrong about this story is that the Cops obtained the BLACK BOX prior to getting a warrant.
They also created a loophole since they probably didnt download anything before the warrant was issued.
These two spoiled schmucks killed someone.
The sad thing is ....I think this post was started cause of the Black Box being used against a driver as opposed to the fact of the crime.
Old Jan 18, 2005 | 04:22 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
No, but when you drive a car on a PUBLIC highway, you implictly agree to abide by the rules. You can drive as fast as you like...on YOUR property. You don't even need a driver's license for that.
Old Jan 18, 2005 | 05:14 PM
Floridasky's Avatar
Floridasky
St. Jude Donor '15
Interesting article. The black box can also verify the fact you were driving good if needed.
Old Jan 18, 2005 | 05:29 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Idiots. Prosecute 'em to the fullest...
Old Jan 18, 2005 | 05:32 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
This has already been going on for years... no way to stop it unless you want to remove the box some way...
VR
Old Jan 18, 2005 | 06:03 PM
WhiteC5Vette
Problem is, the so-called Black box, is the Sensing and Diagnostic Module, and is the "brain" (computer) that controls your air bags. The SDM contains sensing devices that converts vehicle velocity changes to electrical signals. The SDM processes the generated electrical signals and compares them to values stored in memory. When the generated signals exceed the stored values, the SDM performs additional signal processing and compares the generated signals to signals stored in memory. When 2 of the generated signals exceed the stored values, the SDM will cause current to flow through the inflator modules, deploying the air bags. At this time, crash data is stored.
Basically all this stuff works off a single circuit board.
This information cannot be downloaded via Tech 2, it takes special software to download, and special software to decode the hex files obtained.
Some Law Enforcement agencies and lawyers have purchased the software, and it is not cheap. Police can ship the SDM to a representative of GM to obtain the information; however, a court order is required. GM originally designed the system to protect GM from frivolous lawsuits; whereas, people swore (for example) that they stepped on the brakes and the brakes failed. When they actually stepped on the accelerator pedal. Information is also used by engineering.
In addition, most modules top off at around 99-110 mph; however, with the inputs from the other devices a good approximation can be obtained as to the speed at time of collision. For example, if the SDM shows the speed at 99 mph, but the throttle is wide open, engine rpms are increasing over the five second period, and the brake input shows no brake apply, then it can be assumed the person was exceeding any known speed limit in the USA.
I believe as time goes on, this information will be used as much to defend yourself as to find you guilty. I cannot see it being removed, and in fact, more manufacturers are starting to add these types of data recorders to their vehicles.
At this time, I cannot see the police using it to determine if you were doing five or ten over in an accident. Most of the cases I have read about, or heard about via different avenues, have been in regard to speeds in excess of 99+.
Old Jan 18, 2005 | 06:08 PM
  #33
Frizzle86's Avatar
Frizzle86
Originally Posted by 3RD-INF
It won't be long before the police carry a small hand held computer . That will plug into an external plug on your car, and will be able to write you a ticket for sonething you did last week. This will make radar , and radar detectors a thing of the past. Oh yeah Big Brother is watching us.
I highly doubt it would work, cause I know many people would have their units hacked.
Old Jan 18, 2005 | 07:21 PM
  #34
abigfoot's Avatar
abigfoot
Default Box
Old Jan 18, 2005 | 07:34 PM
  #35
Perry Mason's Avatar
Perry Mason
Fifth Amendment (Self Incrimination) does not make this type of evidence inadmissable in court, because it is not testimonial. (Just like breath/blood/DNA samples).
Prediction: Watch how the evolution of GPS systems will result in the "tracking" of vehicles as admissible evidence in criminal cases.
Old Jan 18, 2005 | 07:38 PM
  #36
Perry Mason
While no driver's license is required to drive on private property, a motorist still can be convicted of DUI on that private property. In California, a motorist cannot be convicted of reckless driving on private property, however.
Old Jan 18, 2005 | 07:44 PM
  #37
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Originally Posted by Elpelon
Don't see much differenct between a plane and a car. In each case it is helpfull to determine what caused the accident. What if the jeep had been at fault and cut the corvette in half - now you have proof!
On the otherhand if I'm the stupid one then I expect to pay the price.
Very well put. It could have easily been the other way around. Having worked aircraft most of my career, the crash survivable flight data recorder is invaluable in determining cause. It's about time the auto makers joined in.
To Black Box Evidence Used
Old Jan 18, 2005 | 08:08 PM
  #38
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Originally Posted by F.J.B.
....SNIP
Not to mention. (with all due respect to your friend JTS)
Does anyone need a blackbox to tell that speed was a factor here. Let's not underestimate the ability of a good crime scene investigator.
Old Jan 18, 2005 | 08:30 PM
  #39
ROMA 75's Avatar
ROMA 75
Thanks for the detailed informations Doug.
Old Jan 18, 2005 | 08:38 PM
  #40
ELTGuy_C5's Avatar
ELTGuy_C5
St. Jude Donor '05
I'm not nearly as worried about my "black box" being used if I'm ever at fault in an accident nearly as much as I am worried about two teenage boys having access to high powered sports cars. Those punks deserve whatever they have comming to them, and I would support their parents being charged with allowing a minor to have access to a deadly weapon.
