Polished Wheels
Old Jan 18, 2005 | 12:06 PM
duds's Avatar
duds
Default Polished Wheels
I just purchased a 2000 Vette with polished wheels. What is the process needed to keep these wheels looking good. I understand they need more care than standard wheels, but I have no clue. I am looking for some good advise. Thanks, Duds
Old Jan 18, 2005 | 12:24 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
If the finish is good now, just treat them like you would your paint; wash-dry-wax.
Larry
code5coupe
Old Jan 18, 2005 | 12:44 PM
sjc*2's Avatar
sjc*2
I took a clay bar to the wheels on my 2002 coupe. Really took out the grime that seems to gather in the clearcote of the wheels. Smooth as silk now and look like new. I used the Meguiars clay bar kit. Having done that it is a bit of a ripoff for the small clay bar that they give you. Buy the bars separately and use lots of liquid lubricant.
Old Jan 18, 2005 | 12:57 PM
The polished wheels, if factory, don't take any more care to keep them looking good than the painted ones. Just keep them clean and waxed and you will be OK. They are clearcoated so that helps a lot.
Old Jan 18, 2005 | 12:59 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Larry
code5coupe
Plus, every time you get home, clean 'em. Keep that brake dust off and they'll look good all the time.
You'll probably be surprised at how quickly they will get dirty...
Old Jan 18, 2005 | 01:03 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
What if they have some deposits built up already on the inside (not on spokes)? What is the proper way to take those off?
Old Jan 18, 2005 | 03:19 PM
Dave68's Avatar
Dave68
After cleaning with soap and water, you can use a clay bar with plenty of the detail spray. I generally don't worry too much about the inner areas, but this is what I'd do if I had the time.
Old Jan 18, 2005 | 03:34 PM
wpdjoey's Avatar
wpdjoey
works well for me
Old Jan 18, 2005 | 09:18 PM
2toys's Avatar
2toys
Most of the deposits on the inside,or barrel. of the wheel are "greasy' road grime. You can safely use a rag with kerosene,charcoal lighter fluid or commercial tar remover. Wash off with soapy water,rinse well and apply a coat of car wax.
The wheels on mine looked as if they were never cleaned on the inside. It would be easier to remove them first.
Old Jan 18, 2005 | 11:24 PM
Cajundude's Avatar
Cajundude
Thanks! I was definitely planning on taking them off first. Will clean, clay bar and pile on the layers of Zaino.
Old Jan 19, 2005 | 12:05 AM
MY1STPEWTER's Avatar
MY1STPEWTER
Wash with car wash soap, then Zaino. Between washings when I get back I take a feather duster and knock off what little brake dust is on the wheels. Look good so far.
Old Jan 19, 2005 | 03:01 AM
GrayC5's Avatar
GrayC5
There are several threads on this topic currently going around in the Car Care Products section of the Forum. Good luck!
To Polished Wheels
