[Z06] CCW wheels and rubbing
Old Jan 18, 2005 | 02:18 PM
FST NUF's Avatar
FST NUF
Default CCW wheels and rubbing
I'm looking to buy new CCW classic streets. I want to go 18's all around, ,but wider. My car is lowered 1". Anyone have experience with how wide I can go without rubbing issues? I imagine the tire make would have something to do with this too??
Old Jan 18, 2005 | 02:56 PM
AU N EGL's Avatar
AU N EGL
Yes the tires have something to do with the rubbing. Which tires do you want to get?
I run 18" on all corners. CCW street 18x10 f and 18x11.5 r with Mich PS 275/35 front 335/30 rear. I HAD a rubbing issue. No more the tires rubbed the inside of the rear wheel well out from taking high speed corners.
I also have a set of CCW track, 18x11f and 18x12 rear. To use these wheels I put longer axle lugs on. On the rear I also use a 3/8" spacer.
On the front I also have the DRM brake ducts and yes both sets do rub on extreem full lock turns, However, I dont trun that sharp so no rubbing.
Old Jan 18, 2005 | 04:39 PM
FST NUF's Avatar
FST NUF
Could you imagine I'd have any rubbing issues with 10" fronts shod with 265/35/18 and 11" rears shod with 295/35/18 PS2's? These tires appear to almost mimic the stock parameters across the board. But I'll gain handling (you would think) due to reduced sidewall flex as a result of the increased rim width.
Old Jan 18, 2005 | 07:05 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I'm running 18x9.5 w/ 275's and 18x11 w/ 295's. It's perfect w/ no rubbing. I'm lowered 1"
Old Jan 18, 2005 | 08:08 PM
AU N EGL's Avatar
AU N EGL
As Corbra4B says you will be fine.
Old Jan 18, 2005 | 08:24 PM
FST NUF's Avatar
FST NUF
Thanks guys for the input.
To CCW wheels and rubbing
