Plug in 20+HP....Is this possible?
Old Jan 20, 2005 | 05:00 PM
silvervette97's Avatar
silvervette97
Default Plug in 20+HP....Is this possible?
Looking on Ebay, saw this.........The Performance Module Chip Kit Functions the same as expensive ECU upgrades and Performance chips, like the JET Chip. The Performance Chip connects directly to your vehicles IAT sensor to create a new more optimized signal to your vehicles ECU, This releases the potential of your engine by tweaking the fuel to air ratio to its perfection, causing a richer fuel mixture. COST $7.99
I'm not too confident you can get a HP boost for less than 10 bucks. Anyone out there tried this product or similar product with any success?
Old Jan 20, 2005 | 05:01 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
C5s run rich from the factory. Sounds like to me.
EG
Old Jan 20, 2005 | 05:03 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
Originally Posted by EnglandGreen
Sounds like to me.
if it could be done for $8 GM would have done it for us.
(and charged a couple hundred $$)
Old Jan 20, 2005 | 05:14 PM
Don't think I'll be plugging one of these into my car. Just don't trust it to do what is says.
Old Jan 20, 2005 | 06:30 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
All that thing does is change the computers intake temp. AKA timing tricker.
25 cent resistor at radio shack does the same thing.
It tricks the car to think the temp is 34 degrees.
Old Jan 20, 2005 | 06:33 PM
T's's Avatar
T's
Cruise-In VII Veteran
Crap !
Spend your money on the hood seal, gain 5hp
Old Jan 20, 2005 | 09:12 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
You only get what you pay for. But there are no dumb questions here. Glad you asked before you wasted your money.
Old Jan 20, 2005 | 09:14 PM
dragon84's Avatar
dragon84
ok how about the throttle response plug in thing in Mid America, anyone try this??
To Plug in 20+HP....Is this possible?
