Hood liner removal question?
Old Jan 20, 2005 | 05:22 PM
dragon84's Avatar
dragon84
Default Hood liner removal question?
How hard is it to remove the liner. I see the plastic "tabs", but I question if they will hold up when I pullthem out. Do I need to get new tabs or is there a tried and tested safe way to remove them without damage?
Old Jan 20, 2005 | 05:25 PM
MSGvette's Avatar
MSGvette
I pulled them out by hand. I put them back on with no problems.
Old Jan 20, 2005 | 05:28 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
you can get replacements at the auto parts stores or the dealer..
Old Jan 20, 2005 | 06:14 PM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
I think they were like, 1.80 a piece at the dealer if you screw any up when removing them.
Old Jan 20, 2005 | 08:12 PM
dragon84's Avatar
dragon84
ok cool, thanks guys looks like its time to paint the liner
Old Jan 20, 2005 | 08:17 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Very easy to remove first put a big cloth or sheet to cover the engine so you dont lost any when you pull them out,then just use your hand to pull them up alittle and then just twist them little by little while you pull them out.They wont break and you can reuse them.
Old Jan 20, 2005 | 10:04 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
I found the best way to pull them without hurting your fingers is to use a claw hammer. Pops them out just like pulling nails.
Old Jan 20, 2005 | 10:53 PM
Z0SLIK's Avatar
Z0SLIK
Old Jan 20, 2005 | 11:53 PM
PaulaH's Avatar
0PaulaH
Former Vendor
Purchase a "Door Plug Puller" at a auto supply store for about $5.99.
You can purchase a set of 3 replacement plugs there also for about $1.99.
You can use these plugs over and over and over again, until the threads are bare. Mine have been on and off about 50 times so far and are still working well. For some unknown reason, I always seem to drop one into "never-never" land, and believe me, they never fall to the ground.. Always good to keep a few extras on hand..
Old Jan 21, 2005 | 12:16 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
put the head of the hammer in your hand them insert the claw under the clip. With your hand between the liner and the hammer use the other hand to pry the clip out. This way you don't mess up the liner with the hammer. My .02
To Hood liner removal question?
