UV7 - Windshield Antenna
Jan 23, 2005 | 11:33 PM
Is there any way to improve the reception of tthe radio for those who have the windshield antenna?
Jan 23, 2005 | 11:44 PM
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
My reception is perfect just make sure that both antennas are connected, front and back
Jan 24, 2005 | 12:17 AM
No problems here...
Jan 24, 2005 | 12:19 AM
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Most reputible stereo shops carry a FM Booster. You can try one of those?
Jan 24, 2005 | 01:44 AM
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Vettes have a radio??????
Feb 2, 2005 | 09:42 PM
Quote:
Where are the front and back connections?
Feb 2, 2005 | 09:48 PM
CI 5-6-7-8 Veteran
NCM Ambassador
Quote:
Burn a copy of EGs song and you'll never go back to radio
Feb 3, 2005 | 06:38 AM
They took your radio out to have enough electrical power reserve for your neon............
Feb 3, 2005 | 06:57 AM
Feb 3, 2005 | 08:41 AM
From: Greensboro, NC "REALITY IS MERELY AN ILLUSION, ALBEIT A VERY PERSISTENT ONE"...ALBERT EINSTEIN"
Feb 3, 2005 | 10:37 AM
I assume you have an aftermarket stereo. The reason is for coupes we have 2 antennas, one in the front glass the other in the rear. The OEM radio communicates with a box thats under your lap belt anchor to tell it which antenna to switch to that has better reception (diversity reception). Without this data from the OE headunit, it will try to receive both at the same time which = alot of multipath and cancellation.
My FM is marginal in the city but even worse out where I live. My clockradio picks up more stations. AM is practically non existant. Even worse is when I turn on the rear defrost everything just goes to static.
The solution to this is to either A) put in a whip style antenna from a vert or FRC/z06, or to use a different style antenna in the rear bumper. I ordered one and will let everybody know the results.
Go over to the audio section and check out this thread:
http://forums.corvetteforum.com/showthread.php?t=999271
