C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Octane table question
Old May 24, 2005 | 04:02 AM
boomer 33's Avatar
boomer 33
Default Octane table question
How often does the computer check to see which table to use for proper octane? Just on start up or constant? Wondering for example it detects the low octane on start up and retards the timing etc, will it stay that way until the engine is restarted and it detects higher octane? Thanks
Old May 24, 2005 | 10:34 AM
G-lock's Avatar
G-lock
It chooses a table based on the amount of spark knock it sees, if you KR is intermittent it will have a low knock learn and stay in the HO table. Jeff
Old May 24, 2005 | 12:07 PM
slo-vette's Avatar
slo-vette
Doesn't it blend the two tables together when it sees knock and uses the learned value?
Old May 24, 2005 | 12:46 PM
G-lock's Avatar
G-lock
Good question, I don't believe so, I think when the knock learn reaches a certain threshold it shifts to the LO table, until the next fill up and then it switches back and starts over on the HO table. Jeff
Old Jun 3, 2005 | 10:59 PM
hpcubed's Avatar
hpcubed
It blends the two tables with respect to how much KR.
To Octane table question
