TCS Codes & Reduced Engine Power
http://myweb.accessus.net/~090/dtcobd2c.html#cha
Thanks!
OK, it all started out with what felt like a TPS problem. From idle or off-idle she would stumble or do nothing at all and suddenly send the tires up in a blaze of smoke. A couple days later she started sputtering and missing badly. Then, for no apparent reason she would straiten up and run like a champ.
I found several articles on the forum about ground wire corrosion which helped quite a bit, thank you to those guys. But she's still acting up and throwing codes. Below are several days worth of codes. After recording these I cleared them.
While checking and cleaning connections I unplugged the main computer as well as the one below the carpet on the passenger floorboard. After reconnecting everything including the batter it wouldn't crank at all. I eventually disconnected the harnesses from the computer under the passenger floorboard and it finally would crank and start. I drove her for a few days but when I parked her yesterday she went back to that computer thing where she won't crank at all.
Idea's?
She's dead right now and I'm getting the itch.
OBD II
Diagnostic Trouble Codes: (DTC)
2001 Corvette, Recorded September 16, 2005
10-PCM (1 Code)
P1514HC TAC System MAF Performance
28TCS (1 Code)
C1278H TCS Temporarily Inhibited By PCM
A6 SCM (1 Code)
B2605H Seat Front Vert. Position Sensor Failure
2001 Corvette, Recorded September 07, 2005
A6 SCM (1 Code)
10-PCM (3 Cods)
P0131C HO2S Circuit Low Voltage Bank 1 Sensor 1
P0151H Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
P0174H Fuel Trim System Lean Bank 2
2001 Corvette, Recorded August 29, 2005
10-PCM (3 Codes)
P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1
P0155 HO2S Heater Performance Bank 2 Sensor 1
P0174 Fuel Trim System Lean Bank 2
2001 Corvette, Recorded August 28, 2005
10-PCM (2 Codes)
P0151 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
2001 Corvette, Recorded August 24, 2005
10-PCM (1 Code)
P1514H TAC System MAF Performance
60 IPC (6 Codes)
U1160H Loss of Communications with LDCM
U1040H Loss of Communications with TCS
U1016H Loss of Communications with PCM
U1064H Loss of Communication with DCM
U1088H Loss of Communication with SDM
U1176H Loss of Communications with RFA
80 Radio (3 Codes)
U1064H Loss of Communication w/ DCM
U1096H Loss of Communications with IPC
U1016H Loss of Communication with PCM
AO-LDCM (7 Codes)
B2208H Right Window Down Switch Fault
B2282H Battery #1 Fault
B2284H Battery #2 Fault
U1255H Serial Data Line Malfunction
28TCS (2 Codes)
C1293H DTC C1291/C1292 Set Curnt/Prev Ign Cycle
car died on my wife about 30 minutes from the house, i drive out and she said she had stopped to get gas and after, the car wouldnt start, it was completely dead. no lights, beeps, blinks, nothing electrical. i checked the battery and it looked ok at a glance. serpentine belt was ok, alternator looked ok. i got my tools out and as soon as i put my wrench on the positive terminal on the battery, the post popped out. ah ha, makes sense.
so i get a guy to give me a jump, and once the car is started, i figure i just drive home, or to advance auto, and get a battery. well, 2 minutes after i left the gas station, it started to rain. wipers on, ok. headlights on, and it took a shet. lights flickering, check engine light, codes, etc. reduced engine power comes up on the dic and the car is running like shet, and i cannot keep at speed. i pull over, have a zillion codes, and i start clearing them trying to get it out of reduced power mode. i couldnt so i had to shut it off.
back at the house, hours later, i put a new battery in, and it was all better. for me, reduced power came from the low voltage. at least thats what i think.
Thanks for your feedback, through. It's good to have more to go on.
Take Care!
T.
I think there is info under bad BCM in here somewhere leading to C1278.
Thanks for the replies, keep them coming.
